20 Most Recent Sony Walkman WM-D6C Personal Cassette Player Questions & Answers
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Sony Walkman... | Answered on Aug 27, 2019
Try the line out on the back of the unit and see if sound signal comes out there U must plug that into a preamp on your stereo the signal level is to low for the headphones to sound and if there is sound then u have a blown output amp in the headphones circuit!
Dave Electronic Doctors email [email protected]
Sony Walkman... | Answered on Feb 20, 2019
http://www.galaxyrepairsandspares.com/WALKMAN-REPAIRS
Sony Walkman... | Answered on May 15, 2018
likely something has wrapped around the drive capstan, that would make tapes play faster. Forward and reverse are likely belt issues.
Sony Walkman... | Answered on Sep 08, 2016
this is probably a internal issue, when the keys are pressed, there is a small spring loaded power connected that is pushed together to power the device on and has either got manky and sticky and stuck or spring has failed,
the unit would need to be opened and maybe able to be fixed with some switch cleaner
Sony Walkman... | Answered on Jun 02, 2015
there are little rubber belts inside that attach the motor to the gears that turn the tapes or cd's. over time they stretch out and turn everything slower and slower. you can try replacing the belts, or finding the speed adjustment screw for the motor and turning it up. either one is usually more effort than its worth though. they just weren't designed to last for a long time.
Sony Walkman... | Answered on Jan 24, 2015
You have to replace the IC 601, probably burns because of some passive components that must be replaced. "Doctor.walkman @ gmail.com"
Sony Walkman... | Answered on Aug 29, 2014
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email [email protected]
Sony Walkman... | Answered on Aug 25, 2014
The drive belt has broken - and these will very difficult to get,
Sony Walkman... | Answered on Mar 24, 2014
These are different types of Cassette media available. Normal is regular cassettes. CrO2 is Chromium Dioxide coated. Metal is FeCr, FerriChrome or something like that. I forget what the Dx is, another type of regular media, I think, or a different type of recording type.
Sony Walkman... | Answered on Jan 08, 2014
Sony Walkman WM-D6C Personal Cassette Player Logo
66 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
need 3 way
  • Audio Players & Recorders
