20 Most Recent Sony Walkman WM-FX277 Personal Cassette Player Questions & Answers
there is a good chance you cannot, belts are very hard to get, and if its sony, they are not always easy to get into and often have screws but also have clips, that break upon opening,
its probably better to but a replacment but that too will be hard,
you could try ebay for belt, but it may be better to get a 2nd hand one, or sometime u can get new ones, too
but stay away from aiwa they tend to break down, although offer the best sound, in my opnion
Sony Walkman... | Answered on Jun 02, 2015
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-find.pl?mdl=WM-FX277
Sony Walkman... | Answered on Nov 24, 2010
The black rubber bank is the belt that drives your motor to turn the capstan to eventtually turn the cassette. Now check if the motor is turning the capstan, the larger wheel over which you had wound up the belt. If not check if any connections have been detached when you did the belt change. Within the mechansim there is a small spring leaf switch that activates the motor and the circuits. so check this out or if you can use a multimeter to trace the voltage to the motor and circuit. If this was working prior to your work then look carefully for a careless lapse. I hope you must have wound the belt in the right direction. Helpful? Good day
Sony Walkman... | Answered on Jul 22, 2010
Download the manual from Sony here.
If you want to enter it manually, the full URL is
http://www.docs.sony.com/reflib/docget.asp?manualid=12273&template_id=&region_id=1&DL=',600,560,10,10,'Manuals'
Please take a moment to rate this solution a fixya, and thanks for asking here!
Sony Walkman... | Answered on Dec 20, 2009
cara membuka protect push power sony MHC-RV8
Sony Audio... | Answered on Jul 02, 2020
Hi my Sony mgongo amplifier says usb protect why ??
Sony Audio... | Answered on Jun 30, 2020
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Sony Audio... | Answered on Jun 28, 2020
I suspect there is either a problem with the radio (AM side) or most likely it is a matter of poor AM signal strength where you are and/or high levels of interference.
With FM reception the wire lead of the earphones acts as a fairly efficient antenna but AM reception is via the internal ferrite rod aerial that also is part of the tuned circuit and consequently is not only highly directional but is sensitive to vertical/horizontal orientation - if the signal is polarised vertical the antenna is more efficient when it too is vertical, unfortunately horizontal polarisation is more common.
Development of AM receivers stopped decades ago due to it falling out of favour because of high levels of interference around population centres causing much dissatisfaction and a move to FM and over the last two decades an increased interest in digital radio.
Sony Audio... | Answered on Jun 26, 2020
There's so much information missing from this question, but assuming this is a DVD changer, it's a disc error. Either the disc is upside-down or backwards and can't be read, is too dirty/scratched or unsupported and can't be read, or the entire mechanism is jammed or malfunctioning. If there are discs in the tray and you can remove them all, remove them and see if the error goes away. If the tray will not open, either take the cover off and remove the discs, or bring it to a service center.
Sony Audio... | Answered on May 27, 2020
The internal antenna cud b issue or some capacitor cud b
Sony Audio... | Answered on May 20, 2020
What do you want?
You have to ask a question for us to know what you need to know!
Ask a question and we will try and help!
Sony Audio... | Answered on May 11, 2020
This is a very good make!
You require a phono input or a phono pre amplifier to use this turn table.
There is no phono input on your Yamaha.
Sony Audio... | Answered on Apr 25, 2020
Sony Walkman WM-FX277 Personal Cassette Player Logo
Popular Tags
7 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
lost instruction manual wm fx277
  • Audio Players & Recorders
