20 Most Recent
Sony XM-1002HX Car Audio Amplifier Questions & Answers
Problem with amp
Check your ground it may not be good enough also check to make sure your remote wire is reading 12 volts with the key on. If it doesn't then you run a jumper off your ignitionin the fuse panel.
What is the watts of this amplifier
The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed.
Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sony amp pops, when you
Run an Extra Ground or ReRoute Your Main Ground Straight to the Battery and it should Stop this Popping. Please Rate my Response, I need all the Help That I can Get! Thanks!
Broken output signal
sounds like you have some loose speaker wires somewhere, or touching wires. check to make sure ALL wire connections are solid, and sealed with tape or a connecter. if any wire is touching any metal on the car or another wire it will cause interference
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
- Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
- Check the audio cable for any signs of damage or wear.
- Make sure the auxiliary input is selected as the source on the head unit.
- Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
What is the correct way to hook up a 1000 watt Sony xplod Amp with 1 subwoofer to my Sony mp-40
To properly hook up your 1000 watt Sony Xplod Amp with one subwoofer to your Sony MP-40, you will need to connect the subwoofer to the amplifier using RCA cables. Once the subwoofer is connected, you will then need to use a power cable to connect the amplifier to your Sony MP-40. Make sure the power cable is connected properly and that the amplifier is turned on. After that, you should be able to adjust the settings on the amplifier to get the desired sound from the subwoofer.
My Sony GT90BT car radio is not working. No power on display.
usually one uses a power cycle in order to reset the radio. If the radio is not coming on, the wires powering it could be bad so you'd want to check them with a multimeter for current. Then, you'd want to test the car battery to see if it's still powerful enough to support all of the devices in your car. Then you can get the radio checked.
Thank you.
My Sony car radio keeps scanning but wont hold a station?
Did you do anything around the rear window glass? That is where the aerial is unless you have some other type of antennae. There is also a connector plug under the dash behind the radio. Your signal isn't strong enough for some reason. Have you tried switching between FM and AM channels.
