20 Most Recent Fish Mate Gravity Uv + Bio Pond Filters/3000 Guv 315 (Fish Mate) Questions & Answers
I find cleaning the filter sponge bi-weekly keeps my koi happy. Normally I change bio media once a year and never at the same time as I clean the filter. There are bacteria that colonize the filter that convert the muck into gases and nutrients. So if you clean them both at the same time you remove this cleaning crew and that can cause issues.
Fish Mate... | Answered on Nov 03, 2012
Here is a schematic of the order of the media.
AN-315 - FishMate 3000 GUV - 16 Watt UVC + Bio Pond Filter
123ponds_2173_42032229 Click to close
Fish Mate... | Answered on Aug 31, 2011
fishmate offers replacement impellers - try water landscape supply, http://www.waterlandscapesupply.com
Fish Mate Garden | Answered on Jun 24, 2009
A single pole push button would tie the fused battery feed at the ignition switch B terminal (red/white wire) to the ignition switch S terminal (orange wire).
This provides the same function as turning ignition switch to the start position with all safeties remaining functional. For engine run the ignition switch must be in run position. Push and hold push button until engine run. Turn ignition switch to off position to kill engine.
See link below for wiring diagram located in parts section of manual.
https://www.manualslib.com/products/Troy-Bilt-Ltx-1842-2923621.html
Garden | Answered 7 hours ago
WELL I GUESS YOU NEED TO REMEMBER WHERE YOU BOUGHTIT AND CONTACT THEM SEEMS WE MIGHT NEED TO KNOW A MAKE BUT ALASS YOU FORGOT THAT TOO
Garden | Answered 19 hours ago
That is usually caused by hangups in the pull starter system creating too much friction and not transferring the pull to the motor. Here is the parts diagram and exploded view
https://www.diyspareparts.com/parts/stihl/diagrams/br-380/
Garden | Answered Yesterday
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Garden | Answered 2 days ago
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Garden | Answered on Sep 24, 2020
i wouldnt even consider it. a truck mounted plow makes more sense
Garden | Answered on Sep 22, 2020
check your local home store. they sell things like this
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Garden | Answered on Sep 21, 2020
Make sure that the nozzle is clean. Also the tube between the nozzle and tank. Check inside the tank to be sure there is not any debris in the tank. Is the pump working and building up pressure? Does the cap O ring make a good seal?
This is how to solve the stiff Makita plunge saw easily!!!
I've just carried out the following steps and it's like a new saw.
Clear a table top and grab the following tools:
Philips screw driver
4mm allen key
grease- i used silicone grease
1. Take the base off the saw by removing the 4 x obvious screws.
2. If you look at the saw, you'll see that is pivots on a single pin at the rear. You'll also notice that there is a 4mm allen screw driven into that pin.
3. Remove the 4mm allen screw.
4. Fill the screw hole with grease and drive the 4mm allen screw back in (it'll force grease along the pin internally). Do this 3 or 4 times.
5. Work the mechanism back and forth as if you're plunging the saw- you'll notice that it becomes so much more easy to move.
6. Wipe away the black dirty grease that you have forced out of the pin. Reinsert the 4mm allen screw and tighten
7. refix the base and spring.
8. Job done.
This actually bugged me for ages until i finally decided to have a look and see what the issue was.
Garden | Answered on Sep 20, 2020
Fish Mate Gravity Uv + Bio Pond Filters/3000 Guv 315 (Fish Mate) Logo
6 questions posted
Top Fish Mate Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Fish Mate Garden Expert? Answer questions, earn points and help others
View Most Popular
Fish Mate Garden
  • Fish Mate Garden
Most Popular Question
often clean filter sponge change bio
  • Garden
