20 Most Recent Dremel 10.8V Lithium-Ion Cordless Rotary Tool Kit w/ 40 Accessories - 8000-02 Questions & Answers
3answers
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
11/20/2023 2:43:40 AM • Dremel 10.8V... • Answered on Nov 20, 2023
Dremel won't switch off , have had to remove
Either the switch is defective (most likely) or there is a short (less likely).
If it is still under warranty contact the manufacture or the place you purchased it.
If not then you might dismantle it and check the switch to see if it is defective. Use a volt/ohm meter to check for continuity as you toggle the switch. Also check for shorts in the wires or where the wires connect to the switch.
6/27/2011 1:15:21 PM • Dremel 10.8V... • Answered on Jun 27, 2011
Can i cut travertine tiles with my multi max
If you dimond blade
1/17/2014 5:31:04 PM • Dremel Drills • Answered on Jan 17, 2014
I want to use my USA Dremel Stylus in Europe. I
I presume you want to use a transformer to convert the Europe voltage to USA voltage ( 220 or 240 to 110 )Why not purchase a 240 volt docking station ?Send me the 10 digit number on your Dremel (usually starts with F ) and I can help you.
10/25/2013 7:32:49 AM • Dremel Drills • Answered on Oct 25, 2013
2answers
Where can you find a Dremel model 780 battery
I'm not sure why but, the Dremel 9.6 volt battery is only available through a Robert Bosch retailer or authorized service center. Their homepage is at www.boschtools.com/Pages/default.aspx where you can search for the nearest service center under the 'Service' tab.
10/19/2012 1:50:10 AM • Dremel Drills • Answered on Oct 19, 2012
I bought a dremel 4000 on ebay and it didn't have
Your drill bits side, should have a twisting hand tightening head into which you insert the bits, and have fun. If this is missing, you can either buy it, at dremel stores, or get a nut of the same thread and get the job done.
9/11/2010 12:54:50 AM • Dremel Drills • Answered on Sep 11, 2010
Did not receive manual in my box, for Dremel
go to Dremel.com and they can get you one if they are not available online at that site.
1/23/2010 12:18:20 AM • Dremel Drills • Answered on Jan 23, 2010
Dremel 10.8V Lithium-Ion Cordless Rotary Tool Kit w/ 40 Accessories - 8000-02 Logo
10 questions posted
Top Dremel Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Dremel Drill Expert? Answer questions, earn points and help others
View Most Popular
Dremel Drills
  • Dremel Drills
Most Popular Question
dremel charger model 856 won 39 t
  • Drills
