20 Most Recent Sony XR-F5100 Cassette Player Questions & Answers
Trouble shoot
use a y connector
3.5 mm jack male on one side
aplits into two two wires leading to
one rca plug each mostly whie n red
plug these into line in
hope it helps
2/21/2011 9:59:47 AM • Sony XR-F5100... • Answered on Feb 21, 2011
How can i reset the cd player???
disconnect power to it.
2/26/2010 5:36:13 PM • Sony XR-F5100... • Answered on Feb 26, 2010
Can 2 sony 12 inch 4 ohm subs be paralleled to 2 ohms? i have a 2 ohm stable db drive amp
Resistors (loudspeakers of equal resistance) in parallel ... divide the resistance by 2. Answer to your question is yes, you will have 2 Ohms.
10/20/2022 8:22:42 PM • Sony Car Audio &... • Answered on Oct 20, 2022
My Sony car radio keeps scanning but wont hold a station?
Did you do anything around the rear window glass? That is where the aerial is unless you have some other type of antennae. There is also a connector plug under the dash behind the radio. Your signal isn't strong enough for some reason. Have you tried switching between FM and AM channels.
8/25/2022 5:35:25 PM • Sony Car Audio &... • Answered on Aug 25, 2022
2answers
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
5/2/2022 2:23:17 AM • Sony Car Audio &... • Answered on May 02, 2022
Hello I have a Sony CD headunit (cdx-565up) and the face comes on but you can't do anything but turn it up and down can't switch stations can't adjust nothing just comes on turns up and down that's it
Take a cotton swab with rubbing alcohol and clean each button thoroughly to remove any residue. There is a eject lever on the device that could be out of place. To fix this some minor repair will be needed. Taking the face plate off using the small button on the lower left hand side will give you access to the reset button. Try this before opening up your entire device. Try any above of these Hope it helps you Good luck
3/13/2022 11:45:01 PM • Sony Car Audio &... • Answered on Mar 13, 2022
3answers
I cannot figure out what
dsfdsfsd
12/14/2021 4:09:44 AM • Sony Car Audio &... • Answered on Dec 14, 2021
I have a sony xr c4120 car stereo system. Can i connect mp3 player?
Same question?
11/26/2021 12:35:22 PM • Sony Car Audio &... • Answered on Nov 26, 2021
2answers
Sony explode car stereo wont get any stations on the tuner
aerial is disconnected on the rear or at the rear/front window elements.
10/27/2021 2:53:43 AM • Sony Car Audio &... • Answered on Oct 27, 2021
2answers
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
10/20/2021 11:57:21 PM • Sony Car Audio &... • Answered on Oct 20, 2021
2answers
Best way to run my Sony xplod 1000 watt amp to two dual 4 ohm 10-in speakers
wire one speaker to left and one to right. Do not be confused by impedance. this will work.
10/20/2021 11:55:58 PM • Sony Car Audio &... • Answered on Oct 20, 2021
How to connect 1,200 amp Sony Colo to a Sony Colo CD car stereo
Check here https://freeonlineservicemanual.blogspot.com/2021/07/sound-audio-sound-instrument-manual.html?showComment=1625353857089&m=1#c1718629861852162499
7/4/2021 12:45:29 AM • Sony Car Audio &... • Answered on Jul 04, 2021
Hi !i have 1100 sony xplod,how many subwoofer watts i need?
As many as you want up to the ratings of the speaker.
6/12/2021 11:47:15 AM • Sony Car Audio &... • Answered on Jun 12, 2021
Sony XR-F5100 Cassette Player Logo
4 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
trouble shoot
  • Car Audio & Video
