20 Most Recent Sony DVD-NS530 DVD Player Questions & Answers
HOLD THE BLUE HDD BUTTON ON THE FRONT PANEL FOR MORE THAN 10 SECONDS TO REFORMAT THE HARD DRIVE. THIS INFORMATION IS AT THE BACK OF THE USER MANUAL BUT MAY NOT CURE THE FAULT.
Sony DVD-NS530... | Answered on Nov 29, 2007
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Sony DVD-NS530... | Answered on Apr 08, 2007
https://www.lifewire.com/fix-tv-turns-on-by-itself-4685838f
Sony Televison &... | Answered on Feb 20, 2020
https://www.sony.com.au/electronics/support/articles/00198068
Follow these steps and see if the problem is resolved.
  1. Set the TV audio output setting to PCM.
  2. Change the Sound Bar settings as follow, using the included remote control. Set Sound Mode to Music by pressing the sound mode setting button (Music). Set VERTICAL S. to Off by pressing the VERTICAL S. button repeatedly.
Change your audio setup to stereo. if you are running two speakers
Hello
Blu-Ray players' region hack proceedings are yet to come.
Sony Televison &... | Answered on Feb 17, 2020
After the replacement of the main board; a software update might be necessary to any TV. Contact any service technician, of do it yourself, if you know how to do it. Or Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sony Televison &... | Answered on Feb 12, 2020
Here is a question that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what is does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part your put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'No Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous use it as an excuse to get money for selling items that may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $2 parts and an hours labour. Take it for service.
Sony Televison &... | Answered on Feb 11, 2020
The RMT-TX1020 is not a remote that I find online. There is a Sony RMT-TX102U which is included with several models, including the KDL-32R500C. First, what input are you using on the TV? If you are watching OTA (analog or digital), then if captions are available, you should be able to press the Subtitle (CC) button below the Channel Up/Down buttons on the remote. There are three choices for Caption Display: On/Off/On when sound muted. You can also adjust the type of captions. In most cases, you'll want to use CC1 for both Analog or Digital captions. Navigate through the menu using the select (the center + button) and the arrow keys as with all the other menus. If you are using a set-top box (cable, streaming, Blue-ray player), you probably need to enable the subtitles or captions at that device. It could be in a hardware settings menu and not a function controlled by their remote control.
My current TV setup includes IPTV (fiber-optic internet). To enable subtitles, I need to go to the Menu and then to Settings. Then I enter a password provided by the ISP and go to the Hardware > Audio > Captions menu. On a neighbor's satellite dish receiver that served two TVs, enabling captions on the second TV (for their hearing-impaired relative) required enable captions in the Hardware settings for the primary TV.
The subtitle button usage is described on page 30 on the manual for this TV. Sony has the manual on the product support page: https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs/kdl-32r500c. The current link to the manual is https://www.sony.com/electronics/support/res/manuals/4562/45622791M.pdf .
I hope this helps. Please add a comment with the video source for your TV if you want further assistance.
Sony Televison &... | Answered on Feb 10, 2020
Question:
Sony Televison &... | Answered on Feb 07, 2020
try google but doubt they will work together
Sony Televison &... | Answered on Feb 05, 2020
Televison & Video Logo
7 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
code
  • Televison & Video
