20 Most Recent Sony DVP-S500D DVD Player Questions & Answers
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Sony DVP-S500D... • Answered on Dec 03, 2008
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Sony DVP-S500D... • Answered on Aug 06, 2008
can not as you did not make sure the photo got attached
Sony Televison &... • Answered on May 05, 2021
try a different input then call a local repair service
Sony Televison &... • Answered on May 04, 2021
Follow this: C:31:30 error code shows problem of No FG signal when starting capstan motor. C:31:23 error code shows problem of No S reel signal to system control. Need further info, let me know.
Sony Televison &... • Answered on May 01, 2021
Try this. If this doesn't work, you need to take it to a technician, or treat yourself to a new set. Resetting picture settings
  1. Open Picture and Display settings. From the main settings menu, open the Picture and Display settings, and then Picture Adjustment controls.
  2. Open Advanced Settings. ...
  3. Select Reset. ...
  4. Confirm Reset.
Sep. 11, 2020
How to adjust picture settings on a Sony TV - Sony Bravia ...
Sony Televison &... • Answered on Apr 29, 2021
Use code search on the URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in either WebView, or by desktop. MobileView has no search box.
Sony Televison &... • Answered on Apr 26, 2021
Old things forget what they are told to do . tape units are a thing of the part
Channels 515, and channel 516? They will be accessed via the cable box, and possibly channels that you have to be subscribed. https://www.google.com/search?q=Channels+515%2C+and+channel+516 ..
Sony Televison &... • Answered on Apr 09, 2021
The 'jungle' chip is the sync separator, video processor and timebase chip all in one. They rarelly fail.
Sony Televison &... • Answered on Apr 08, 2021
Do a factory reset to this set, and then check. To make it factory reset, you have to enter its service mode. If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Service mode entry procedure of almost all Sony TVs [LCD & CRT] are similar.
Sony Televison &... • Answered on Mar 15, 2021
Sony DVP-S500D DVD Player Logo
6 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
wavy lines
  • Televison & Video
