20 Most Recent
Zvue Elvis Presley MP3 Player Questions & Answers
Cant put videos on it
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
My sreen craked and went
There really isn't a good solution for this. To replace a cracked screen would most likely cost more than getting a new one. Sorry for the bad news.
No video software came with
Conect the ipod player to the computer where controls are acquired. For example, the computer would provide accessibilty to the mp3 player. media playes like windows media player, real one player, apple media players, juke box media convertors are the audio, video management software programs on the computer. As long as the computer would acquire media as videos, the computer mediaprofram should provide the transfer buttons between external connectable devices like mp3 players. However, the media players have various compartibilities recognisable as media formats. The mp3 player should have dictated the compartible format that is capable of being encoded. Important notes includes that, mp3 playes would only encode medias that have been loaded onto the computer completely. For example, if wanting to acquire music transfer to the mp3 player device, the music CD has to be extracted first into the computers media player like windows media player from where transferability is achievable into the MP3 player. Usually, the computer media player should state that the feature functionality is capable of MP3 IPOD transfers. For example, once login to the windows media player software, copy available media files from the files library into the player list area to be manipulated as transfers/sync. Also, the media player of the computer should recognise connected media devices with popup logos indicating transfereabilities.
How to delete music from
Try this way...BE REALLY CAREFUL NOT TO DELETE YOUR FIRWARE only your songs,etc.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Video Format for ZVue Elvis - .mtv not recognized
The elvis media player comes with the conversion software on the player in a .zip file. Transfer it to your pc. unzip it. install it. It should solve your problem. Reading the instruction manual is a must. If you have the files on your unit I could use a copy of the .zip files. Please attach and send to
[email protected]. The 1 gig partition shows up as drive F on my computer and is fully compatible with windows xp and above. If you formatted your disk you are out of luck. like me. Now I know but it's too late unless some nice person sends me the .zip files. Thanks.
Where is the volume control
Not sure about your model but it looks like the volume is the 3rd button down on the front of the player. This is true only if it has three buttons on the front.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
