20 Most Recent Sony KP-61HS20 TV Questions & Answers
manual
21answers
I see a box and Video 1 "behind" my picture
if you can see it at all times then yes it has been burnt into your screen. this may have happened if you were using some kind of electronic (game console) on the video 1 setting the tv may have also been left on that channel for a long period of time.
1/5/2009 3:14:26 AM • Sony KP-61HS20... • Answered on Jan 05, 2009
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
6/2/2008 7:18:20 AM • Sony KP-61HS20... • Answered on Jun 02, 2008
Blurry video
You got some wrong advice I am afraid. Hope it was not a Tech that told you this LOL As i would never call them again!! LOL No such thing as that in a projection TV set. Your problem is the convergence IC's inside the TV set, on a printed circuit board. Both will need to be repalced. If you have some solid state repair experience, you could unsolder these IC's and reinstall new ones, but if you do not please play it safe and call in a pro to assist you in this repair. Good Luck.
4/2/2007 5:37:10 AM • Sony KP-61HS20... • Answered on Apr 02, 2007
WONT TURN ON
If you know how to trouble shoot solid state electronics and know how the curcuits work, then Im sure you can handle this repair. But my friend a tv set is not a place for a handy man to be experimenting around inside of, as there is alot of high voltage inside this set even when its turned off! Its best if you do not know all of the safty issues to seek out a pro to assist you in this repair. It could be a bad solder connection, or a bad filter capacitor that supplys the B+ to the video chip. Without looking at a schematic and tracing the circuit, its all a guess. There are no real user replacable parts inside this set. Good Luck PS please do not forget to rate this thread.
11/25/2006 5:48:03 PM • Sony KP-61HS20... • Answered on Nov 25, 2006
Loss of picture
When the power indicator flashes on a Sony it is saying "Hey, I lost high voltage". You are probably going to need a new Horizontal Output Transistor, a flyback transformer and possibly a High Voltage Block. None of the parts are that expensive from Tritronics (www.tritronicsinc.com). I just got them the other day for less than $100. You're better off just replacing everything mentioned rather than doing it piecemeal, once and done. I don't know whether you're capable of this repair or not. If you aren't sure have a professional do it. If you are going to proceed, remember safety! TVs are dangerous. Good luck.
6/23/2006 9:29:43 PM • Sony KP-61HS20... • Answered on Jun 23, 2006
How to repair a Sony xbr-85x850g tv for vertical lines
Hi, Please run a channel scan and remove all accessories from the printer. If this does not work, please power cycle your tv before checking for the fixed display again. Otherwise, you might need to factory reset the tv in order to overcome the issue. Thank you.
12/2/2022 3:20:31 AM • Sony Televison &... • Answered 2 days ago
2answers
Sony EV S2000 drop down digital display not working
Hi, Please disconnect and then reconnect every line that's connected to your Sony device to ensure that you've plugged in everything correctly. Then, you can power cycle your device before checking for the issue. If issue still exists, please double check that the source of the content has no issues and then you can switch to a different temporary display to test whether the first display is defunct. Thank you.
11/29/2022 2:29:13 AM • Sony Televison &... • Answered on Nov 29, 2022
How to repair fuse sony bdp-s3700 no power where is the fuse box located
bad power board
11/25/2022 9:40:05 AM • Sony Televison &... • Answered on Nov 25, 2022
How to connect an older sound system to my Samsung smart TV.
Hi, Yes, please start with attempting to plug the sound system input into the appropriate inputs on your smart tv and then check the sound of various channels on your tv. If this does not work, please reference the manual for the sound system in order to get your sound working. And lastly, if that doesn't work, I would suggest working with your local Geeksquad/Bestbuy via a home service. Thank you.
11/24/2022 12:05:14 AM • Sony Televison &... • Answered on Nov 24, 2022
My Sony STR-DN850 IR will not work on receiver
1. Check your receiver's input: If you're having trouble getting your Sony STR-DN850 to play nice with your receiver, the first thing you should do is check the receiver's input. Make sure that the receiver is set to the correct input for the Sony STR-DN850. If you're not sure, consult your receiver's manual. 2. Check your Sony STR-DN850's output: Next, you'll want to check the Sony STR-DN850's output. There are a few things you can check here. First, make sure that the Sony STR-DN850 is set to output audio to your receiver. You can do this by going into the Sony STR-DN850's menu and checking the "Audio Out" setting. Second, make sure that the Sony STR-DN850 is outputting audio in the correct format. If you're not sure, consult your Sony STR-DN850's manual. 3. Try a different receiver: If you're still having trouble, you may want to try a different receiver. Sometimes, different receivers can play nicer with the Sony STR-DN850 than others. If you have a friend or family member with a receiver, see if you can borrow it for a few days to see if it makes a difference. 4. Check your receiver's remote: Finally, if you're still having trouble, you may want to check your receiver's remote. Sometimes, the remote can be the culprit when it comes to receiver/Sony STR-DN850 compatibility issues. Make sure that the remote is set to the correct input for the Sony STR-DN850 and that all the buttons are functioning properly. If you're still having trouble, you may need to consult your receiver's manual.
11/22/2022 4:48:21 PM • Sony Televison &... • Answered on Nov 22, 2022
Sony TV XBR-43X800G solarized picture, how to fix
If you're seeing a solarized picture on your Sony TV XBR-43X800G, there are a few things that could be causing the issue. Here's how to fix it. First, check the input source. If you're using an HDMI cable, try switching to a different input. If you're using a component cable, make sure it's securely connected to the TV. If the input source isn't the issue, try resetting the TV. To do this, unplug the TV from the power outlet and then plug it back in. Once the TV is back on, go to the Settings menu and select Picture. Scroll down to Picture Mode and select Standard. If you're still seeing a solarized picture, there may be an issue with the TV itself. In this case, you'll need to contact Sony customer support for assistance.
11/22/2022 4:48:01 PM • Sony Televison &... • Answered on Nov 22, 2022
2answers
My Sony VCR will not accept a tape and displays 71101 as the error code.
Hi John, I searched under "error code 71101 sony VCR" you'll get quite a few hits including fixya but there are several others which could be worth a look.
11/22/2022 4:47:07 PM • Sony Televison &... • Answered on Nov 22, 2022
How to fix tv with constant blinking green and orange lights and tv doesn't come on
How to fix a tv with constant blinking green and orange lights: If your TV has been constantly blinking green and orange lights, it is likely that there is a problem with the power supply. The first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it. How to fix tv with tv doesn't come on when plugged in: If your TV doesn't come on when plugged in, the first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it.
11/22/2022 3:15:41 AM • Sony Televison &... • Answered on Nov 22, 2022
Sony g14q1 sound with highly noise on RF signal
1. Sony g14q1 sound with highly noise on RF signal: If you're experiencing issues with your Sony g14q1 sound system, it could be due to a noisy RF signal. Here's what you can do to fix the problem and prevent it from happening again. 2. The problem and how to fix it: The problem with the Sony g14q1 sound system is that it produces a high-pitched noise when an RF signal is present. This can be annoying and make it difficult to enjoy your music. To fix the problem, you can try a few things. First, make sure that you're using the correct audio cables. If you're using an HDMI cable, try a different one. Sometimes, the problem can be caused by a faulty cable. If that doesn't work, you can try turning off the Dolby Digital Plus feature. This feature can sometimes cause interference with the RF signal. To do this, go to the Settings menu and select "Sound." Then, scroll down to the "Dolby Digital Plus" setting and turn it off. If you're still having issues, you can try moving the receiver to a different location. Sometimes, the problem can be caused by interference from other electronic devices. So, if you move the receiver away from those devices, it might help to reduce the noise. 3. Sony's response to the problem: Sony has acknowledged the problem and is working on a fix. In the meantime, they've released a statement saying that they're "aware of the situation and are investigating."
11/22/2022 3:07:53 AM • Sony Televison &... • Answered on Nov 22, 2022
My sony KDL "46vl160" sound is out of sync
1. Check your TV's audio settings: If you're experiencing audio issues with your Sony TV, the first thing you should do is check the audio settings. Make sure that the TV is set to output audio to the correct source. For example, if you're using an HDMI cable to connect to a sound bar, make sure that the TV is set to output audio to the sound bar. If you're using a receiver, make sure that the TV is set to output audio to the receiver. 2. Try a different HDMI cable: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different HDMI cable. Sometimes, the cable can be the issue. 3. Check your sound bar's audio settings: If you're using a sound bar, make sure that the sound bar is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, make sure that the sound bar is set to the HDMI input. 4. Check your receiver's audio settings: If you're using a receiver, make sure that the receiver is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the receiver, make sure that the receiver is set to the HDMI input. 5. Try a different audio input: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, try connecting the TV to the receiver using an optical cable. 6. Restart your TV: If you're still experiencing audio issues, try restarting your TV. Sometimes, this can fix the issue.
11/22/2022 1:49:52 AM • Sony Televison &... • Answered on Nov 22, 2022
Manual for sony rm-ed007 where to get
https://www.servicemanuals.net/en/sony-service-manuals
11/21/2022 2:53:45 AM • Sony Televison &... • Answered on Nov 21, 2022
Sony KP-61HS20 TV Logo
7 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
see box video 1 behind picture
  • Televison & Video
