Sony FD... • Answered on Nov 19, 2015
Sony FD... • Answered on Nov 17, 2015
Sony FD... • Answered on Dec 05, 2014
Sony FD... • Posted on May 28, 2014
Sony FD... • Posted on Feb 11, 2014
Sony FD... • Answered on Jan 27, 2014
Sony FD... • Answered on Dec 30, 2013
Sony FD... • Posted on Oct 20, 2013
Sony FD... • Answered on Aug 13, 2013
Sony FD... • Answered on Nov 27, 2012
Sony FD... • Answered on Aug 20, 2012
Sony FD... • Posted on Feb 04, 2012
Sony FD... • Answered on Dec 30, 2011
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
Sony FD... • Answered on Dec 13, 2010
58 questions posted
1,429 Questions
874 Questions
716 Questions
647 Questions
601 Questions
