20 Most Recent Sony KV-LX34M80 34" TV Questions & Answers
Dear all
I use a Sony crt tv Model KV-LX34M80 in long time but some days ago I face a problem in my television, Emgg, say's damage my television flyback. So I code not find flyback in my location. Please help me.
Sony KV-LX34M80... | Answered on Jun 25, 2019
Contact the authorized service center for Sony. No other way to get it. It is not available at open electronic spare part market.
Sony KV-LX34M80... | Answered on Mar 04, 2015
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Sony KV-LX34M80... | Answered on Jul 26, 2010
A common point of failure in LED backlight television is one LED will fail and the power supply wont come on. Many people replace the power supply board and it wont repair the problem. You have to replace the LED light strips.
Sony Televison &... | Answered on Apr 04, 2020
Press and hold the "Setup" button, which is located in the top left corner of the remote. The light at the top of the remote should start flashing. Now, hold down the "TV" button located on the top right corner of the remote and enter the code simultaneously.
https://www.techwalla.com/articles/how-to-program-a-sanyo-universal-remote
Sony Televison &... | Answered on Apr 03, 2020
Problem is a bad capacitor on the power board. Caution if repairing yourself as capacitors in TV's hold a charge long after set is powered off and can be lethal.
When looking at your power board for a bad cap look at the top of the capacitors. A bad cap will have a noticable "bulging" on the top of it compared to others. Be sure to note polarity of capacitor (will have a "-" on one side indicating negative. To fix on/off issue simply unsoldered bad capacitor and solder in a new one with same voltage and capacitance rating being sure the new capacitor is oriented the same as the old one was before it was removed.
Sony Televison &... | Answered on Mar 31, 2020
It's something about the Burlesque dvd. I have the same problem with mine when I try and play it on my Sony blue-ray player. It's the only disc I have that it won't play. Disc is a DVD Video disc but it will no't play in the Sony player. It plays fine on other dvd players and my computer, but not on the Sony.
On the left pane, select Settings. Select Configuring the TV. Select [TV]. to pull up the settings menu on the right pane of the TV screen.
https://www.sony.com/electronics/support/articles/00175354
Sony Televison &... | Answered on Mar 30, 2020
good day if apprat after the fall, there is a huge probability of damage to the matrix itself (display) or the display backlight lamps (they are very thin and fragile to be found directly behind the matrix), which is probably why the inverter writes an error (the block that drains the ignition of these lamps), the operation to replace these lamps is a very painstaking and complex process. if I were in your place, I would leave it to the specialists from the qualified SC.
Sony Televison &... | Answered on Mar 29, 2020
Push down and pull the back cover off.
41x8bk2fedl._ac_-undefined-undefined-0.jpg 41ibq02h5gl._ac_-undefined-undefined-2.jpg
Sony Televison &... | Answered on Mar 27, 2020
https://www.revoxremotes.com/Remotes/Sony_RM-VZ320.htm
Sony Televison &... | Answered on Mar 25, 2020
When a power supply gives trouble it often means a fault elsewhere is causing an overload - an age related shift in component values can cause the current consumption of a circuit to increase yet remain functional. This sort of condition is likely to cause stress to the power supply so it slowly cooks...
Sony Televison &... | Answered on Mar 18, 2020
Sony KV-LX34M80 34" TV Logo
Popular Tags
11 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv lx34m80 34 crt tv specs service
  • Televison & Video
