20 Most Recent
Sony KV-35S66 35" TV Questions & Answers
Picture flashes on and off
How many times do it flashes at a time? Count these blinks. These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty location to an extent. Count it for more than two times after switch off and switch on the set.
Visit this site if you want more details about the blinking codes to Sony TVs. You haven't provided the exact number of blinks here. If so, I might give you more details.
I purchased my Sony KV-35S66 in Dec. 1999. The
No,this tv is fixable.The video board,that the board,that connected to the CRT (Tv Tube),those round pins holes that connected CRT sockets that hold the CRT(Tv Tube) and the video board together.Resolders those CRT pins sockets that connected on to the video board.Will solved the cold solders connections between the CRT pins sockets and the video board this problems,will be solved.Tries take it to a tv shop,ask them take the tv aparts,resolder the video board CRT pins hole sockets on the video board for you.The priced my guest about $35-40.They must,take tv cover out and resolder the vdieo board CRT pins holes sockets.The whole job,take about 20-30 mins.
Has audio no video
THE CAUSE FOR THIS WOULD BE THE FLYBACK TRNSFORMER.
The best thing to do here is ether have it repaired arond $120 bucks or a new tv because of the age of the unit and other factors. I would recommend a newer model set.
But its up to you at this point
questions?
please do leave a rating and feedback for your free answer today. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have an old Sony tv from 1992 and it's image is
Vertical out transistors bad solder, or return linearity capacitor bad (a large capacitor, usually between 1000uf and 2200uf.) They're near where yellow and brown wires from picture tube connect to main board. They are larger transistors.
Vertical sweep repair
it may be quite hard and expensive. Unless you get lucky and find the exact blown output transistor by luck, I recommend that you search for a schematic first and then an oscilloscope and isolation probe. more economical to get another tv
No pic/sound from inputs
Already post other solution about this. On Sony TVs, the common problem is loose connections. Your TV have a ssb ( vertical position) unplug and re solder. Other thing, Tuner will be in loose connection too. Try and I hope this work for you.
[email protected]
Your IC audio be short , replaced . Before turn on check capacitor around audio section ( re solder area)
Green face
Component Degaussing problem om power supply ( maybe loose connections)
No picture or sound
Sounds like you have bad solder connections on the 5 and 9 volt regulators on the power board. They should be marked 7805, 7809, and possibly 7812. The 78 on these IC's mark that they are positive regulators and the other 2 numbers signify what voltage they are. Very common problem.
I want to use tv as a pc monitor
You'll have to have a video card with an S-Video output if your not doing so now. Then on your computer you need to go to your control panel, then select monitor settings and set it up from there. Beware that using a television as a monitor is grossly deteriated. For the audio, you need a stereo mini jack to RCA phono plug cable to plug to go from your sound card to the audio input.
No pictures on my SONY 35"
HOW DID YOU EXPLAIN THE TROUBLE I THINK YOU HAVE A PROBLEM WITH HIGH TENSION , MAY BE TRANSISTOR OR
FLYBACK TRANSFORMER OR A COMPONENT NEAR TO THAT
IF YOU DON'T BE ABLE TO CHECK , YOU MUST GO TO REPAIR
IT TO TV SERVICE
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sound but no picture
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
