20 Most Recent Sony KV-27XBR45 27" TV Questions & Answers
A bright white line across the middle of the screen indicates vertical sweep output failure. Check and repalce dmaged component/s in the vertical output section circuit. Check for any loose solder terminals around the the vertical output section circuit. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Sony KV-27XBR45... • Answered on Nov 11, 2012
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Sony KV-27XBR45... • Answered on Jul 05, 2011
Unplug the set and give it a shot. Nothing to lose at this point. Considering the age of the set, it's not worth getting it fixed anyway.
Sony KV-27XBR45... • Answered on Apr 27, 2010
Here a website to get the original remotes.1-800-Remotes Factory original.To buy exact remotes or very close to the original.No other way,tv control on the front of the tv don't have functions to work for PIP.
Sony KV-27XBR45... • Answered on Nov 03, 2009
check the RCA jacks it could be defective..
Sony KV-27XBR45... • Answered on Mar 04, 2009
If you have a cell phone or wireless internet this may cause interference. If you have any of these close them out and see if it still does the sound.
Sony KV-27XBR45... • Answered on Feb 15, 2009
If you open up the back and locate hte fluback transformer (part with large red wire coming out of the top), you should see two controls on that tramsformer. One is the screen control which will control the overall brightness of the picture and the other (bottom I think) is a focus control. It may be marked on the transformer itself as well. Turn that control slightly while watching the set. This should resolve the problem.
Dan
Sony KV-27XBR45... • Answered on Jul 08, 2008
I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
Also check for open or defective diode on flyback transformer for the 200 vdc source.
I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
Good Luck.
Sony KV-27XBR45... • Answered on Jan 15, 2008
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Sony KV-27XBR45... • Answered on Dec 28, 2007
Try and tune your remote back into the TV
Sony KV-27XBR45... • Answered on Nov 20, 2007
Sounds more like bad blue gun in CRT. A tv shop with a
good quality pix tube checker / rejuvenator may give some
temporary help......................T.
Please rate this solution..........
Sony KV-27XBR45... • Answered on Nov 14, 2007
You have connected the speakers to the audio line out sockets. These are meant for connection to an amplifier and are not suitable for what you are attempting. If there are no connections on the back of the TV specifically for loudspeakers then you will need to add an amplifier or Home cinema reciever.
Sony KV-27XBR45... • Answered on Oct 06, 2007
Channels 515, and channel 516? They will be accessed via the cable box, and possibly channels that you have to be subscribed. https://www.google.com/search?q=Channels+515%2C+and+channel+516 ..
Sony Televison &... • Answered 3 days ago
The 'jungle' chip is the sync separator, video processor and timebase chip all in one. They rarelly fail.
Sony Televison &... • Answered on Apr 08, 2021
Do a factory reset to this set, and then check. To make it factory reset, you have to enter its service mode. If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Service mode entry procedure of almost all Sony TVs [LCD & CRT] are similar.
Sony Televison &... • Answered on Mar 15, 2021
Televison & Video Logo
21 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv 27xbr45 slighly out focus
  • Televison & Video
