20 Most Recent Sony KV-27V55 27" TV Questions & Answers
How to access the menu
Without a remote control, you can't. Electrohelponline
3/4/2015 12:35:54 PM • Sony KV-27V55... • Answered on Mar 04, 2015
Sony sony kv-25v25 no power
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1/14/2014 2:35:44 PM • Sony KV-27V55... • Answered on Jan 14, 2014
Samsung cs-29z45 no power
Check and replaced damaged component/s at its main power regulator [SMPS] section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1/14/2014 2:32:58 PM • Sony KV-27V55... • Answered on Jan 14, 2014
Sony Model KV-27V55
Check the audio output circuit side. Check the audio output IC.
1/23/2013 5:47:01 PM • Sony KV-27V55... • Answered on Jan 23, 2013
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
1/23/2013 5:40:13 PM • Sony KV-27V55... • Answered on Jan 23, 2013
No sound no picture
Set may be too old to repair----power supply is down (likely shorted) and average cost will be well over 100 to fix the set.
12/3/2012 3:55:01 PM • Sony KV-27V55... • Answered on Dec 03, 2012
I have SONY TV Model
It is possible that this is a power failure within the power supply. But sometimes there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
8/22/2011 6:56:29 AM • Sony KV-27V55... • Answered on Aug 22, 2011
2answers
My TV (KV27V55) bought in
This is quite fixable but who knows how long it will take in good condition since it rendered 17years of service.You have to consider if it is worth than buying another high end unit. First ask the repair shop an estimate for service fee plus parts to have an idea how much money you are going to spend sending your unit to shop.
Thanks for using fixya.
1/23/2011 1:22:17 AM • Sony KV-27V55... • Answered on Jan 23, 2011
2answers
My Sony KV-27V55 27" TV has not picture
look for vertical hold.
5/24/2010 1:41:07 AM • Sony KV-27V55... • Answered on May 24, 2010
No power on my ony KV-27V55 27" TV
check the power convergence transistors
5/24/2010 1:38:04 AM • Sony KV-27V55... • Answered on May 24, 2010
I have a problem with my tv sony kv-27v55, the
the problem is the vertical or the horizontal part of the video
10/27/2009 1:14:11 PM • Sony KV-27V55... • Answered on Oct 27, 2009
Sony kv-27v55 sound but no picuture
check plyback hope will can help..
8/15/2009 1:35:19 PM • Sony KV-27V55... • Answered on Aug 15, 2009
Sony KV-27V55 Completely Dark
tv power supply problem
1/26/2009 3:49:29 PM • Sony KV-27V55... • Answered on Jan 26, 2009
0answers
Sony KV32s45 sudden failure
I really have to say there is no miracle cure for TV's I have 20years of experience in fixing TV's I don't suggest for you to try to fix this as TV's run on high voltage and you could kill yourself.
If you really cannot find a tech to check it for you the only thing you can try is to check for a broken fuse.
You Must Take Great Caution.
If you are a person that like to take things apart you may try to take the back off .
Start by disconnect the power cable and follow the main power cable inside , normally it goes where the main switch is located and there you should find a Time Fuse normally the value is around 2.5 amps T for time it should say on circuit board & on fuse.Check for a faulty fuse.If faulty replace with the same type fuse and before you plug it in put back all covers than you may try to put on TV.
If fuse is good than fit back cover and take to a professional.
3/13/2008 7:21:52 AM • Sony KV-27V55... • Answered on Mar 13, 2008
Distorted Screen
It sounds like the the power supply or the horizontal circuit is faulty, it is very likely you must take your TV to a professional repairer.
3/13/2008 7:03:28 AM • Sony KV-27V55... • Answered on Mar 13, 2008
Sony KV-27V55 27" TV with no remote
Nope, you can order a new remote here if you want to pay the price, around $65 plus s&h www.wehaveparts.com theres no other way to activate service mode, BMW Rider
1/4/2008 4:14:01 AM • Sony KV-27V55... • Answered on Jan 04, 2008
2answers
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
10/14/2007 6:06:22 PM • Sony KV-27V55... • Answered on Oct 14, 2007
Televison & Video Logo
25 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
samsung cs 29z45 no power
  • Televison & Video
