20 Most Recent Sony KV-27S65 27" TV Questions & Answers
Check all the solder terminals at the CRT base board. Check for any loose contact there. Unplug and re plug all the plugged socket once. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Sony KV-27S65... • Answered on Oct 17, 2012
that problem is very common on a sony tv,the sound IF and video IF of your tv is bad..video and sound IF is located near the tuner section of your tv.some sony model,the IF section and TUNER section are packed in one enclosure. it your tv sound IF is packed together with the tuner,then replace the tuner with a new one.some are packed separately so you need to replace just the IF module only..you can also try to adjust the IF by using a plastic smsll screw driver adjust the IF clock wise or counter clock wise untill you achive a good reception do it with the tv power is on..be carefull with the high voltage...
tnx and please rate my help..
Sony KV-27S65... • Answered on Jun 05, 2010
verticle amplifier is not working on your tv
take it to a shop if you dont know.
verticle IC BE CHECKED.
AND ELETROLITIC CAPACITOR feeding verticle scan coil.
Sony KV-27S65... • Answered on Apr 16, 2009
You should be able to find the remote control code at this website. Good Luck→
http://www.tvcodes.com/index.html
Sony KV-27S65... • Answered on Mar 22, 2009
my tv screen just turned brown. sound and everything else works fine?????
Panosonic HD tv
Sony KV-27S65... • Answered on Nov 13, 2008
The problem here is that the vertical IC either has bad connections or is defective. Look for a small flat IC with about 11 pins attached to a heat sink. It will be marked LA7837 or something similar. Try resoldering the pins on the IC first. If that fails to resolve the problem replace the IC.
Keep us posted.
Dan
Sony KV-27S65... • Answered on Jun 03, 2008
If you put the back of your hand to the front of the picture screen does it make the hair stand out like static? If not there is no high voltage..Does the audio come from the receiver to the tv or to a suround sound system? My first suggestion is to disconnect the tv from every thing. Plug in an exterior antenna/rabbit ears or just a paper clip into the cable connector and see if you get any local channels. If you have none available, connect to a known good dvd or vcr and see if it works correctly. If so then something has died in the receiver modulator. It might then be possible to use only the audio/video outputs on the receiver to get everything working, however the problem could be deaper in the receiver and not able to be bypassed.....Let me know what you have tried and if anything works. etc.....
Sony KV-27S65... • Answered on Feb 11, 2008
I had a similar problem and opened the box and blew out a ton of dust. Still don't know what the problem was, but the sound came back.
Sony KV-27S65... • Answered on Feb 10, 2008
HI
Is the original flyback number: fcm20a025? I work in a shop repairing televisions, might have a good spare I could send you.
Mark
Sony KV-27S65... • Answered on Dec 27, 2007
I am using sony 2062 model since year 1982
& most of my friends are using 2032 since that time.
of course we have modified it to increase channels.
but in my opinion it is like gold.
excellent colour & picture.
so i can say it has minimum life of  20 years with good light.
hope this will help.
Sony KV-27S65... • Answered on Oct 17, 2007
helo your problem is very easy try to adjust the I F control along jungle section. hope you can make it
Sony KV-27S65... • Answered on Jun 25, 2007
The Sony part number for these diodes is 8-719-108-12 and yes they are 9.1 volt zener diodes @ 1 watt. I have the service manual for this set if you need it put can only send a large file like this trough a proggy called pand, so if you go to pando.com and get the proggy and leave youe e-mail addy I will send you a copy of this service manual. Good Luck
Sony KV-27S65... • Answered on Mar 30, 2007
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
Sony KV-27S65... • Answered on Mar 16, 2007
can not as you did not make sure the photo got attached
Sony Televison &... • Answered on May 05, 2021
try a different input then call a local repair service
Sony Televison &... • Answered on May 04, 2021
Follow this: C:31:30 error code shows problem of No FG signal when starting capstan motor. C:31:23 error code shows problem of No S reel signal to system control. Need further info, let me know.
Sony Televison &... • Answered on May 01, 2021
Try this. If this doesn't work, you need to take it to a technician, or treat yourself to a new set. Resetting picture settings
  1. Open Picture and Display settings. From the main settings menu, open the Picture and Display settings, and then Picture Adjustment controls.
  2. Open Advanced Settings. ...
  3. Select Reset. ...
  4. Confirm Reset.
Sep. 11, 2020
How to adjust picture settings on a Sony TV - Sony Bravia ...
Sony Televison &... • Answered on Apr 29, 2021
Use code search on the URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sony KV-27S65 27" TV Logo
18 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv 27s65 27 television suddenly
  • Televison & Video
