20 Most Recent Sony KV-32FV15 32" TV Questions & Answers
Will not start 5 blinks
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
8/23/2012 10:01:07 AM • Sony KV-32FV15... • Answered on Aug 23, 2012
Will my Sony 32FV15 receive/display HGTV
Yes, it will work. You can plug any source into it and it will work.
7/31/2010 12:20:09 AM • Sony KV-32FV15... • Answered on Jul 31, 2010
Cable remote doesn't turn tv on or off nor volume
Sounds likw you need to program remote or get someone to do it for you.
Remotes will not work with everything but still need programming
12/30/2009 10:22:24 PM • Sony KV-32FV15... • Answered on Dec 30, 2009
A teck came from a warranty company and said that
If a tech came to your home they should have an authorized paper and phone number that you can call to check to see if the tech is authentic.
Sounds like you have registered your TV and that they have found that this board has a problem and Sony is willing to take care of it.
Blessings,
A/V Media Guy
11/22/2009 3:39:43 AM • Sony KV-32FV15... • Answered on Nov 22, 2009
The HD video input channel has a slanted, dual picture.
check for the settings or the inputs doesnt match with the unit.
7/31/2009 3:03:30 AM • Sony KV-32FV15... • Answered on Jul 31, 2009
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
8/5/2008 5:45:06 PM • Sony KV-32FV15... • Answered on Aug 05, 2008
Picture won't turn on, but sound does...
yes i beleive you some stuffs do have a feeling. anyway, the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, vif,sif, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
1/16/2007 6:09:02 AM • Sony KV-32FV15... • Answered on Jan 16, 2007
How to connect an older sound system to my Samsung smart TV.
Hi, Yes, please start with attempting to plug the sound system input into the appropriate inputs on your smart tv and then check the sound of various channels on your tv. If this does not work, please reference the manual for the sound system in order to get your sound working. And lastly, if that doesn't work, I would suggest working with your local Geeksquad/Bestbuy via a home service. Thank you.
11/24/2022 12:05:14 AM • Sony Televison &... • Answered on Nov 24, 2022
My Sony STR-DN850 IR will not work on receiver
1. Check your receiver's input: If you're having trouble getting your Sony STR-DN850 to play nice with your receiver, the first thing you should do is check the receiver's input. Make sure that the receiver is set to the correct input for the Sony STR-DN850. If you're not sure, consult your receiver's manual. 2. Check your Sony STR-DN850's output: Next, you'll want to check the Sony STR-DN850's output. There are a few things you can check here. First, make sure that the Sony STR-DN850 is set to output audio to your receiver. You can do this by going into the Sony STR-DN850's menu and checking the "Audio Out" setting. Second, make sure that the Sony STR-DN850 is outputting audio in the correct format. If you're not sure, consult your Sony STR-DN850's manual. 3. Try a different receiver: If you're still having trouble, you may want to try a different receiver. Sometimes, different receivers can play nicer with the Sony STR-DN850 than others. If you have a friend or family member with a receiver, see if you can borrow it for a few days to see if it makes a difference. 4. Check your receiver's remote: Finally, if you're still having trouble, you may want to check your receiver's remote. Sometimes, the remote can be the culprit when it comes to receiver/Sony STR-DN850 compatibility issues. Make sure that the remote is set to the correct input for the Sony STR-DN850 and that all the buttons are functioning properly. If you're still having trouble, you may need to consult your receiver's manual.
11/22/2022 4:48:21 PM • Sony Televison &... • Answered on Nov 22, 2022
Sony TV XBR-43X800G solarized picture, how to fix
If you're seeing a solarized picture on your Sony TV XBR-43X800G, there are a few things that could be causing the issue. Here's how to fix it. First, check the input source. If you're using an HDMI cable, try switching to a different input. If you're using a component cable, make sure it's securely connected to the TV. If the input source isn't the issue, try resetting the TV. To do this, unplug the TV from the power outlet and then plug it back in. Once the TV is back on, go to the Settings menu and select Picture. Scroll down to Picture Mode and select Standard. If you're still seeing a solarized picture, there may be an issue with the TV itself. In this case, you'll need to contact Sony customer support for assistance.
11/22/2022 4:48:01 PM • Sony Televison &... • Answered on Nov 22, 2022
2answers
My Sony VCR will not accept a tape and displays 71101 as the error code.
Hi John, I searched under "error code 71101 sony VCR" you'll get quite a few hits including fixya but there are several others which could be worth a look.
11/22/2022 4:47:07 PM • Sony Televison &... • Answered on Nov 22, 2022
How to fix tv with constant blinking green and orange lights and tv doesn't come on
How to fix a tv with constant blinking green and orange lights: If your TV has been constantly blinking green and orange lights, it is likely that there is a problem with the power supply. The first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it. How to fix tv with tv doesn't come on when plugged in: If your TV doesn't come on when plugged in, the first thing you need to do is to check the power cord and make sure that it is properly plugged into the outlet. If the power cord is not the problem, then you need to check the fuse box and make sure that the fuse is not blown. If the fuse is not the problem, then you need to check the power supply itself. If the power supply is the problem, then you will need to replace it.
11/22/2022 3:15:41 AM • Sony Televison &... • Answered on Nov 22, 2022
Sony g14q1 sound with highly noise on RF signal
1. Sony g14q1 sound with highly noise on RF signal: If you're experiencing issues with your Sony g14q1 sound system, it could be due to a noisy RF signal. Here's what you can do to fix the problem and prevent it from happening again. 2. The problem and how to fix it: The problem with the Sony g14q1 sound system is that it produces a high-pitched noise when an RF signal is present. This can be annoying and make it difficult to enjoy your music. To fix the problem, you can try a few things. First, make sure that you're using the correct audio cables. If you're using an HDMI cable, try a different one. Sometimes, the problem can be caused by a faulty cable. If that doesn't work, you can try turning off the Dolby Digital Plus feature. This feature can sometimes cause interference with the RF signal. To do this, go to the Settings menu and select "Sound." Then, scroll down to the "Dolby Digital Plus" setting and turn it off. If you're still having issues, you can try moving the receiver to a different location. Sometimes, the problem can be caused by interference from other electronic devices. So, if you move the receiver away from those devices, it might help to reduce the noise. 3. Sony's response to the problem: Sony has acknowledged the problem and is working on a fix. In the meantime, they've released a statement saying that they're "aware of the situation and are investigating."
11/22/2022 3:07:53 AM • Sony Televison &... • Answered on Nov 22, 2022
My sony KDL "46vl160" sound is out of sync
1. Check your TV's audio settings: If you're experiencing audio issues with your Sony TV, the first thing you should do is check the audio settings. Make sure that the TV is set to output audio to the correct source. For example, if you're using an HDMI cable to connect to a sound bar, make sure that the TV is set to output audio to the sound bar. If you're using a receiver, make sure that the TV is set to output audio to the receiver. 2. Try a different HDMI cable: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different HDMI cable. Sometimes, the cable can be the issue. 3. Check your sound bar's audio settings: If you're using a sound bar, make sure that the sound bar is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, make sure that the sound bar is set to the HDMI input. 4. Check your receiver's audio settings: If you're using a receiver, make sure that the receiver is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the receiver, make sure that the receiver is set to the HDMI input. 5. Try a different audio input: If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, try connecting the TV to the receiver using an optical cable. 6. Restart your TV: If you're still experiencing audio issues, try restarting your TV. Sometimes, this can fix the issue.
11/22/2022 1:49:52 AM • Sony Televison &... • Answered on Nov 22, 2022
Manual for sony rm-ed007 where to get
https://www.servicemanuals.net/en/sony-service-manuals
11/21/2022 2:53:45 AM • Sony Televison &... • Answered on Nov 21, 2022
3answers
7 time blinks tv sony kd-65x8500f
The 7 blinks on your TV is letting you know then that there is an error with the temperature of your TV or the sensor is not working or your TV is overheating. Or there is is an issue with the KD board or the GD board or an audio error.
11/16/2022 4:31:14 PM • Sony Televison &... • Answered on Nov 16, 2022
My Sony PSP won't play discs. Is it finally dead, or is it a simple fix?
It might now of have stopped working on you guys and is no longer working anymore too and someone had sold you a bad playstation portable unit.Or you can buy another one from a reputable places like JJ games and DKOldies and East Starland games. download-undefined-undefined-0_3.png
11/14/2022 8:58:43 AM • Sony Televison &... • Answered on Nov 14, 2022
Sony KV-32FV15 32" TV Logo
Popular Tags
12 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
picture turn but sound
  • Televison & Video
