20 Most Recent Sony FD Trinitron WEGA KV-32FV300 32" TV Questions & Answers
2answers
Flickering
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
2/20/2012 8:11:44 PM • Sony FD... • Answered on Feb 20, 2012
Sony FD Trinitron Wega KV-FV300.
Symptom shows that main circuit board of tv got some loose connection/ loose connector some where that is causing problem and slap/ hit on tv cabinet connect that connection temporarily for some time.
If you are handy with electronics stuff repair and can do solder work then check/ inspect solder joints on circuit board and resolder any dry/ cold solder joints/ connections that look dull or not shiny as compare to nearby solder joints.
If you are not familiar dong so then local tv repair shop will do this job for you.
Hope these info will help, let me know if there is additional question.
Thanks.
6/26/2011 10:27:58 PM • Sony FD... • Answered on Jun 26, 2011
0answers
2answers
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
8/28/2010 6:29:04 AM • Sony FD... • Answered on Aug 28, 2010
My TV is stuck on
Hi and welcome to FixYa,
Using the Sony's original remote, go to MENU, Channel settings and change "Channel Fix" to Off.
Good luck and thank you for asking FixYa.
1/13/2010 4:23:40 PM • Sony FD... • Answered on Jan 13, 2010
My sony trinitron tv turns off right after I turn
an internal component has failed in the t.v. a tech will have to look at it.
the clicking sound is a relay in the protection circuit turning off the t.v.
11/11/2009 1:05:22 AM • Sony FD... • Answered on Nov 11, 2009
I have replaced the horizontal output transistor
I would first be suspicious of the flyback transformer if the HOT was shorted. I have also found many Sonys with shorted video output i.c. s which are on the CRT pc board. I do not recall if this model uses one output i.c. or three separate ones. Either way you can unplug the cabling feeding the crt board and try powering the set again. If the high voltage comes up you likely have a shorted video i.c. (The i.c. s short most likely because the crt momentarily arcs.) If this test does not result in a clearing of the over current problem I would, as I said initially, suspect the flyback. There are other possible causes, but those are the two I have seen most often.
11/10/2009 10:12:50 PM • Sony FD... • Answered on Nov 10, 2009
My Sony Trinatron KV32F16 tv was working great.
This is a hardware problem which can't be done by the owner of this tv. Try to find a technician who will help you.
9/11/2009 2:16:18 AM • Sony FD... • Answered on Sep 11, 2009
Initial Setup
Resoldering your IC Program
5/16/2009 1:46:12 AM • Sony FD... • Answered on May 16, 2009
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
4/19/2009 6:25:54 PM • Sony FD... • Answered on Apr 19, 2009
32 wega trinitron
surprised it went 12 most 8-9 not Worth the fix
2/6/2009 1:03:28 AM • Sony FD... • Answered on Feb 06, 2009
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
9/10/2008 1:53:55 AM • Sony FD... • Answered on Sep 10, 2008
Sony 19"
How many times does the green light flash? This green light can tell you the area where the problem is but it will not tell you what is bad.
8/16/2007 4:58:10 PM • Sony FD... • Answered on Aug 16, 2007
1/3rd of Bottom portion of Screen is blacked out
sound like you have cloced caption text on, this is not the same as the normal cloced caption, look on your rempte for caption or "cc". if you don't see it you will find it in your menu & turn it off. have a good day.
1/2/2007 1:34:47 PM • Sony FD... • Answered on Jan 02, 2007
How to turn on TV without it's original remote control? it's a Sony model:PDM-4210. WEGA ENGINE
Try downloading an app from Sony on your phone, use the cell as a remote.
3/24/2023 12:45:34 PM • Sony Televison &... • Answered 14 hours ago
Sony Bravia KDL-65W850A is returning a 4-blink error code.
Your TV has quit working and has also died.The T conn board is bad or there is a power supply problem.
3/22/2023 6:39:31 AM • Sony Televison &... • Answered 2 days ago
Can I program a sony rmt-d197a DVD player remote control to an older Sanyo tube TV?
Sony remote control have no0 set-up codes to Sanyo TVs.
3/16/2023 7:49:41 AM • Sony Televison &... • Answered on Mar 16, 2023
Help, the sony slv-x715 video cassette recorder does not read the cassette. Error code : 3L 22 AA, tried 10 cassettes to no avail
If your Sony SLV-X715 VCR is not reading the cassette and you are receiving the error code 3L 22 AA, there could be a few potential issues causing the problem. Here are some steps you can try to troubleshoot the issue:
  1. Clean the Video Heads: The error code you are seeing may be related to dirty or clogged video heads. Try using a cleaning cassette to clean the heads and see if this resolves the issue.
  2. Check the Cassette Compatibility: Ensure that the cassette tapes you are trying to use are compatible with your VCR. Some tapes may not be compatible due to their format or quality. Check the user manual to ensure that you are using the correct cassette tapes.
  3. Check the Cassette Loading Mechanism: Ensure that the cassette is properly inserted into the VCR and that the loading mechanism is functioning correctly. Check for any obstructions or damage to the mechanism that may be preventing the cassette from loading properly.
  4. Reset the VCR: Try resetting the VCR by unplugging it from the power source for a few minutes, then plugging it back in and trying again.
  5. Contact Technical Support: If none of the above steps work, you may need to contact Sony technical support for assistance. They can provide you with more specific troubleshooting steps or guide you through the process of repairing or replacing your VCR if needed.
It's worth noting that the error code you are seeing may indicate a specific issue with your VCR, so you may want to consult the user manual or online forums for more information on what the code means and how to address it.
3/9/2023 2:04:43 PM • Sony Televison &... • Answered on Mar 09, 2023
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
23 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony fd trinitron wega kv fv300
  • Televison & Video
