20 Most Recent Sony FD Trinitron WEGA KV-36FV300 36" TV Questions & Answers
Blink times
You're asking about the details of blinking codes I assumes. If you wish to get more details of this, check the sites linked here. It has blinking code details to many rand TVs, with possible faults. Pull up older posts. google.com/+GopakumarGopalan
11/25/2013 7:06:32 AM • Sony FD... • Answered on Nov 25, 2013
The tv turns on and off and blinks five times
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.google.com/+GopakumarGopalan
11/19/2013 7:55:08 AM • Sony FD... • Answered on Nov 19, 2013
0answers
My sony kv-36FV300 will not respond. won't turn
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
5/13/2010 8:46:53 PM • Sony FD... • Answered on May 13, 2010
Sony 36fg-36fv300
plug tv directly into the wall and not through the cable box.
5/4/2010 1:07:12 AM • Sony FD... • Answered on May 04, 2010
I have a Sony Trinitron KV-36FV300 10+YRS old. the
plug it directly into the wall....not into the cable box
5/4/2010 1:03:13 AM • Sony FD... • Answered on May 04, 2010
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
7/29/2009 10:20:43 AM • Sony FD... • Answered on Jul 29, 2009
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
6/4/2008 6:46:00 AM • Sony FD... • Answered on Jun 04, 2008
Blank screen
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
1/22/2008 7:04:34 PM • Sony FD... • Answered on Jan 22, 2008
Tv stopped working
HV problem. I'm sorry but there is a time for the TV dudes to come see everyone and this is your turn...accordianman
11/28/2007 12:42:47 AM • Sony FD... • Answered on Nov 28, 2007
Continually rolls thru inputs
Make sure the remote cannot be "seen" by the set in question. My guess is the buttons on the remote are transmitting without anyone pressing them....accordianman
10/20/2007 7:04:21 AM • Sony FD... • Answered on Oct 20, 2007
No picture
This mogiht be a problem in the High Voltage power supply. Or the Horizontal output section of the TV. I would start off by checking the Horizontal Output Transistor and the using a high voltage probe check the CRT anode voltage to make sure it is proper. If you do not have a background in electronics I would not suggest that you attempt to work on this set.
10/11/2007 10:12:02 AM • Sony FD... • Answered on Oct 11, 2007
Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
5/2/2006 6:49:41 PM • Sony FD... • Answered on May 02, 2006
Need programming code for Sony STR-D1011
Yes
5/20/2024 9:35:25 PM • Sony Televison &... • Answered on May 20, 2024
STV5112 AND M5101B WHAT IS THE DIFFERENCE?
STV5112 is a 3 channel video output/processing IC for television in a Multiwatt 15 pin case. M5101B is not listed.
5/20/2024 6:30:31 AM • Sony Televison &... • Answered on May 20, 2024
2answers
Can I program a sony rmt-d197a DVD player remote control to an older Sanyo tube TV?
Sony remote control have no0 set-up codes to Sanyo TVs.
5/12/2024 12:32:46 PM • Sony Televison &... • Answered on May 12, 2024
Program dish IR remote to Sony Bravia Television please?
Question edited for spelling of television model. Program Remote to TV or Other Device
  1. Press the HOME button twice, or the MENU button once, depending on your remote.
  2. Select Settings.
  3. Select Remote Control.
  4. Arrow to and select the device code you want to learn.
  5. Select the appropriate Pairing Wizard for the device.
  6. Follow the on-screen prompts.
MyDISH https://my.dish.com > products > remotes > how-to > pr... Program Remote to TV or Other Device - MyDISH - Dish Network ..
5/9/2024 4:01:39 PM • Sony Televison &... • Answered on May 09, 2024
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered on Apr 22, 2024
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
18 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
no signal
  • Televison & Video
