20 Most Recent Sony FD Trinitron WEGA KV-30HS510 30" TV Questions & Answers
you most likely hooked it up incorrectly, or you don't have the little tab set to display in the proper format (HDTV/standard) on the a/v cord. Or ou purchased a broken 360. Oh your a/v cord could be busted too.
Sony FD... • Answered on Jan 12, 2010
This TV is indeed HD ready.
Sony FD... • Answered on Nov 29, 2009
A loud pop in the speakers is one of two things. 1. DC voltage from the amp instead of the normal AC.(If this is the case the amp is slowly burning the voice coils of the speakers.) 2. a large spike to the input of the amp. (This would be less common, but possible.) The problem is probably in the amp itself. The speakers will get spoilt if not taken care.
Thanks
Sony FD... • Answered on May 31, 2009
theres a service bulliten out on this problem called"TVP0424" It explains about wide screen format problems and adjusting vert bow and hH trap adjustment. Good Luck
Sony FD... • Answered on Apr 25, 2006
can not as you did not make sure the photo got attached
Sony Televison &... • Answered 3 days ago
try a different input then call a local repair service
Sony Televison &... • Answered on May 04, 2021
Follow this: C:31:30 error code shows problem of No FG signal when starting capstan motor. C:31:23 error code shows problem of No S reel signal to system control. Need further info, let me know.
Sony Televison &... • Answered on May 01, 2021
Try this. If this doesn't work, you need to take it to a technician, or treat yourself to a new set. Resetting picture settings
  1. Open Picture and Display settings. From the main settings menu, open the Picture and Display settings, and then Picture Adjustment controls.
  2. Open Advanced Settings. ...
  3. Select Reset. ...
  4. Confirm Reset.
Sep. 11, 2020
How to adjust picture settings on a Sony TV - Sony Bravia ...
Sony Televison &... • Answered on Apr 29, 2021
Use code search on the URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in either WebView, or by desktop. MobileView has no search box.
Sony Televison &... • Answered on Apr 26, 2021
Old things forget what they are told to do . tape units are a thing of the part
Channels 515, and channel 516? They will be accessed via the cable box, and possibly channels that you have to be subscribed. https://www.google.com/search?q=Channels+515%2C+and+channel+516 ..
Sony Televison &... • Answered on Apr 09, 2021
The 'jungle' chip is the sync separator, video processor and timebase chip all in one. They rarelly fail.
Sony Televison &... • Answered on Apr 08, 2021
Sony FD Trinitron WEGA KV-30HS510 30" TV Logo
9 questions posted
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
hooked up xbox360 trinitron but get no
  • Televison & Video
