20 Most Recent Sony FD Trinitron WEGA KV-13FS100 13" TV Questions & Answers
A Black Banner with a code along with the date and time
Not enough information?
12/19/2013 1:45:18 AM • Sony FD... • Answered on Dec 19, 2013
0answers
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
1/30/2013 5:16:07 PM • Sony FD... • Answered on Jan 30, 2013
The standby timer on my sony trinitron keeps turning off tv
What is the exact model number to your Sony Wega?
11/9/2012 7:23:07 AM • Sony FD... • Answered on Nov 09, 2012
KP-51WS520 53 inch stand-by button blinks 9 timesWhat's your problem?
power supply try here http://www.shopjimmy.com/
9/6/2012 1:56:03 AM • Sony FD... • Answered on Sep 06, 2012
Sony kv-13fs100 keeps on blinking
Hi, below are Sony blinking codes are thier solutions...Hope it helped...
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.
7/9/2011 5:09:24 PM • Sony FD... • Answered on Jul 09, 2011
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
5/29/2011 3:15:09 AM • Sony FD... • Answered on May 29, 2011
The power switch does not connect immediately. I
Hello
I consider our complaint is against the front panel power switch of your Sony TV, and posts this solution. Sony telivision power switches are of two pole single throw types and soldered direltly to the main printed circuit board. Your complaint is related with its poles contact inside. They can be defective, and is not repairable. Replacing ti is the only solution. To do this, disconnect the TV from AC mains first, and open it. Draw out the main printed circuit board, and will come with the switch. Desolder the switch out from the board, and go for a new one. It can be purchased from most of the electronic spare part shops. Keep the sample with you. Note its legs position and its pitch. Replacing it will solve your problem. Ok.
1/28/2011 3:32:47 PM • Sony FD... • Answered on Jan 28, 2011
TV fixed on one channel. Cannot change channels.
The remote control and the keys are all serial inputs to the samecontroller. It seems as though the controller can read them but noaction is taken, including no display of the function activated (volumebar, etc.) so it's likely that either the sensor or the remote control is damaged. Try replacing the current remote and test it with a universal remote control. If it works then there is no problem with the sensor the with the remote control. Just replace it.
Visit this guide on remote control troubleshooting.
http://esupport.sony.com/US/perl/tutorial-display.pl?tut_id=298&mdl=KV13FS100
3/24/2009 5:32:03 PM • Sony FD... • Answered on Mar 24, 2009
3answers
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
12/4/2008 7:10:39 PM • Sony FD... • Answered on Dec 04, 2008
Sony KDL-32EX340 won't turn on
You could try testing the power supply by using a multimeter to look for voltage and see if any of the components are bad. If you can't find a schematic of the power supply, you may want to consider visiting a local electronics store or repair shop to get more help. Additionally, you could try replacing the fuse to see if that helps, but it would be best to confirm that is the issue before replacing it
1/30/2023 1:50:29 AM • Sony Televison &... • Answered on Jan 30, 2023
Sony VPL-CS5 Red LCD isn't working
If your Sony VPL-CS5 Red LCD isn't working, you may need to replace the lamp. You can purchase a replacement lamp from the manufacturer's website or from an authorized retailer. You may also need to check the power cord and connections to ensure that everything is properly connected. If the issue persists, you may need to contact Sony customer service for further assistance.
1/29/2023 8:21:12 AM • Sony Televison &... • Answered on Jan 29, 2023
Looking for remote control code to operate Philips 65PFL4864 TV from Sony BDP-S370's remote (RMT-B107A).
If you're trying to control your Philips 65PFL4864 TV with the remote control of your Sony BDP-S370 Blu-ray player (model RMT-B107A), you will need to find the remote control code that corresponds to your TV. The codes for different brands and models of TVs can vary depending on the remote control, but you can try using one of the following codes:
  • Code 020
  • Code 021
  • Code 022
  • Code 023
  • Code 024
  • Code 025
  • Code 026
  • Code 027
To use the codes, you need to follow these steps:
  1. Turn on your TV and Blu-ray player
  2. Press and hold the "TV" button on the remote control of your Blu-ray player.
  3. While holding the "TV" button, enter one of the codes listed above.
  4. Release the "TV" button and check if the TV responds to the commands from the remote control.
  5. If the TV does not respond, try the next code in the list.
You should be able to find the instructions on how to program your remote control in the manual of your Blu-ray player. If you don't have the manual, you can download it from the Sony website or contact the manufacturer for assistance. Keep in mind that these codes are not guaranteed to work, and it's possible that your remote control may not be able to control your TV. In this case, you may need to consider purchasing a universal remote control that is compatible with your TV and Blu-ray player.
1/25/2023 6:26:26 PM • Sony Televison &... • Answered on Jan 25, 2023
Sony 60" High Definition LCD Projection Television - Model KDF-60WF655; SN: 9036329, has wide green stripes showing vertically across the screen.
perform a soft reset. Turn off the TV, unplug the connector from the socket, and wait 2 minutes. ...
1/19/2023 1:13:23 AM • Sony Televison &... • Answered on Jan 19, 2023
2answers
Sony KDL-60-EX screen not lighting up, red light blinks 6 times, what could it be?
kindly check the power board if all voltages are there
1/16/2023 11:42:37 PM • Sony Televison &... • Answered on Jan 16, 2023
How to get my sony dvd DVP-C670D out of standby mode without a remote?
  1. Power button: Locate the power button on the front or side of the DVD player. Press and hold the button for a few seconds until the device turns on.
  2. Power outlet: Unplug the DVD player from the power outlet and then plug it back in. This should turn the device on.
  3. Power strip: If the DVD player is plugged into a power strip, turn off the power strip and then turn it back on. This should turn the device on.
  4. Manual: Consult the manual of your DVD player if you have one, it may have a way to get the device out of standby mode.
  5. Using the buttons of the DVD player: Some DVD players have a button on the front or back of the device that can be used to turn it on and off. If the device has a button, try pressing it to turn it on.
It's worth noting that these methods may vary depending on the specific model of your Sony DVP-C670D DVD player. If none of these methods work, you may need to purchase a replacement remote control or consult a professional for assistance.
1/15/2023 1:17:23 AM • Sony Televison &... • Answered on Jan 15, 2023
Best way to connect sony Bravia TV, RDR-HXD890 recorder and Sky Q box, please??
Connecting your old RDR-HXD890 player/recorder to your Sky Q box and TV can be done by using the appropriate cables and connections. Here is an example of how you can connect the devices:
  1. Connect the HDMI output of the Sky Q box to the HDMI input of the RDR-HXD890 using an HDMI cable. This will send the video and audio signals from the Sky Q box to the RDR-HXD890.
  2. Connect the HDMI output of the RDR-HXD890 to the HDMI input of the TV using an HDMI cable. This will send the video and audio signals from the RDR-HXD890 to the TV.
  3. Connect the aerial cable to the aerial input of the RDR-HXD890
  4. Connect the RDR-HXD890 to the power outlet
  5. Turn on all the devices and set the TV to the HDMI input where the RDR-HXD890 is connected.
By connecting your devices in this manner, you will be able to watch and record TV shows and movies from your Sky Q box through the RDR-HXD890 and display them on your TV.
1/13/2023 11:40:06 AM • Sony Televison &... • Answered on Jan 13, 2023
HOW DO I PROGRAM BRIVIAL SONY TV
To program a Sony TV, you will need to follow these steps:
  1. Press the "Menu" button on your remote control.
  2. Use the arrow buttons to navigate to the "Settings" menu, and then press the "Enter" button.
  3. Navigate to the "Installation" or "Setup" menu, and then press the "Enter" button.
  4. Select "Programming" or "Channel Setup," and then press the "Enter" button.
  5. Follow the on-screen instructions to scan for available channels. This will typically involve selecting your cable or antenna source and then initiating the scan.
  6. Once the scan is complete, use the arrow buttons to navigate through the list of channels and select the ones you wish to keep. Press the "Enter" button to lock them in.
  7. Exit the menu when you are finished.
Note that the specific steps may vary depending on the model and software version of your Sony TV. You may refer to the manual of the TV to get more information.
1/13/2023 11:03:42 AM • Sony Televison &... • Answered on Jan 13, 2023
Sony FD Trinitron WEGA KV-13FS100 13" TV Logo
Popular Tags
16 questions posted
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
turn stand light flashes timers
  • Televison & Video
