20 Most Recent
Sony WEGA KDE-50XBR950 50 in. Plasma HDTV Questions & Answers
My Sony WEGA KDE50XBR950 began to display the
I had this same problem last wk. It is either the heat sensor or the fan problem. My was the heat sensor and I took it to a local TV shop and they replace it for $250. For such a good TV, it is worth the $250 to fix vs. trying to buy a new one of such quality for $1000, that may not even have such as good pictures.
I bought a new 60LG 1 month ago for $2200 and it is no where as goo as this old 720P Sony in picture quality.
One question, do you still have the original TV stand that come with this TV? If you are not using it, I would like to buy it from you. I mounted the TV originally, but now want to take it off the wall and use a TV stand in another room. Please email me at
[email protected]
9/26/2012 9:00:16 PM •
Sony WEGA...
Answered
on Sep 26, 2012
Sony 50
Did you get this issue fixed? If not and you are giving up on this TV, I would like to buy the original Table stand that came with this TV from you if you still have them. I currently mounted this TV but looking to move it to another bedroom but I lost the original TV stand. Please email me at
[email protected].
1/29/2011 11:16:23 PM •
Sony WEGA...
Answered
on Jan 29, 2011
I have a Sony KDE-50XBR950 plasma tv. I have a
CONTACT SONY.For those issues sony had a repair facility that would send you a box to ship it in to a place with with a clean room to and equipment to replace data driver I.C.s you should contact them about that issue. I'm not sure if they only deal with sony pro equipment or if its the place is around anymore . the only other alternative i know of is to replace the plasma panel.
1/29/2011 11:15:08 PM •
Sony WEGA...
Answered
on Jan 29, 2011
I have a sony kde-50xbr950 and when I tried to
Hi
Thanks
for using FixYa. A plasma TV is a very hard working device. It is
working harder than any TV that has been built before, and as a result it
produces a lot of heat. 75% of technical problems in plasma TV's are caused by
overheating problems. X, Y sustain, buffer boards controls
picture, fires the gas, and many others functions. When either of these boards goes
bad common problems include negative image, no image, vertical or horizontal
stripes on picture, turns on and than turns off, and many more. You’ll need to
open the back off the TV and check for any swollen/bulged/leaky capacitors on these
boards and replace whichever has gone bad. All this is only recommended if you
have electrical expertise & know how to solder/re-solder components as these
units contain high voltages even when switched off.
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
1/13/2010 3:21:22 AM •
Sony WEGA...
Answered
on Jan 13, 2010
Need a new xy board
You can buy the parts. The best way to find replacements over the internet is to search by the part number on the boards. It should be in white letters and numbers.
Most internet sites list it by part number. Because different LG models lines and parent company TV lines uses the same part.
10/22/2009 5:56:38 PM •
Sony WEGA...
Answered
on Oct 22, 2009
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
8/30/2008 7:10:05 PM •
Sony WEGA...
Answered
on Aug 30, 2008
My sony FLASHES 4 times
( no vertical deflection Vstop IC 1509, Q1505)
http://www.iwaynet.net/~nesda/SonyBlink.html
1/3/2008 10:58:52 PM •
Sony WEGA...
Answered
on Jan 03, 2008
