20 Most Recent
Sony PVW-2600 VCR Questions & Answers
Error 008
DRUM TROUBLE Drum Motor rotation is not normal. Tape protection is initiated.
Sony Betacam SP PVW-2600P wont
there is a problem on the mechanical loading system of your recorder this is often cause by a dislocated timing gears some are cause by a foreign objects that blocks the movement of the mechanism. to resolve this problem open the cover and have a close look to the mechanism remove any objects that might block the mechanism.Re align the timing gears replace any brocken/damage gears.be very careful when dismantling the mechanism this task is not easy if you do not have any background in electronics I would suggest to consult a skilled technical personnel to do the job for you. good luck and let me know if you need further assistance..
Sony pvw 2600 VCR we
Error 10 relates to a condensation or Dew warning. Unplug the deck and let sit for a day. It should be okay.
Sony PVW-2600 Flashing lights on control panel
If this control panel has the hard brown plastic LED holders, that could be the problem. They can absorb moisture from the atmosphere, corrode the LED leads, and deposit a conductive goop (that's a technical term) on the PCB, screwing up the lamp logic. Replace all the holders- Sony only sells a new, improved version- and any LEDs with corroded leads. Clean the PCB thoroughly with alcohol to get rid of all the goop, and you should be fine.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
