20 Most Recent Sony SLV-R1000 S-VHS VCR Questions & Answers
I need part,BACK TENSION LEVER for Sony VCR SLVR1000
Contact the authorized service center for Sony. http://electronicshelponline.blogspot.com/
6/11/2014 3:24:16 AM • Sony SLV-R1000... • Answered on Jun 11, 2014
3answers
Supply loading arm gear
tyvm BobbyR1234 !!
Sony Part Number: 3-736-147-01
Threading Gear, left side, supply side
http://www.partstore.com/Part/Sony/Sony/SLVR1000/Sony/Sony/373614701/New.aspx
Part applies to models:
Sony DECK-SON-M1 | Sony SLV-555UC | Sony SLV676UC | Sony SLV-770HF | Sony SLV353UC | Sony SLV559 | Sony SLV686HF | Sony SLV-771HF | Sony SLV373UC | Sony SL-V575UC | Sony SLV-696HF | Sony SLV900HF | Sony SLV393 | Sony SLV-579 | Sony SLV750 | Sony SLV920HF | Sony SLV39UC | Sony SLV585HF | Sony SLV750HF | Sony SLVR1000 | Sony SLV494HF | Sony SLV-595HF | Sony SLV757UC | Sony SLVR5UC
5/15/2014 11:36:31 AM • Sony SLV-R1000... • Answered on May 15, 2014
There is no video coming from SLV-R1000 it is just
See if the left side loading pin wraps the tape all the way around the video head; if it doesn't more than likely the blue gear , #3-736-147-01, is broken in half .Replacements are available for $4-$11.00 + shipping.
9/2/2013 7:53:14 PM • Sony SLV-R1000... • Answered on Sep 02, 2013
Svl-r1000 year 2008
You have really solved your own question, the unit does not have in the microprocessor the means to go past a certain date.
12/21/2012 6:11:41 PM • Sony SLV-R1000... • Answered on Dec 21, 2012
I need pdf user manual
Hello
I've the document you asks. Send me a mail and get it as an adobe acrobat document. It comes upto 11MB capcity, and I can't send it to you through this site. Please note your need also in the mail, sometimes I may forget this. OK.
[email protected]
1/28/2011 4:45:25 PM • Sony SLV-R1000... • Answered on Jan 28, 2011
I had someone bring a 1985 tape to be transferred
yes there are head cleaning tapes available. You cannot use them for an hour after cleaning as you put a few drops of fluid in the hole that is transferred to the tape and then to the head, The transport reels are something it does not clean,.
Use 70% alcohol ( chemist) to clean the rollers.
It may be that the tape you were trying to copy is deteriorating amd may clag up the works again.
Please rate my help++++Thanks for using FIXYA
5/21/2010 3:20:17 AM • Sony SLV-R1000... • Answered on May 21, 2010
POWERS OFF BY IT'S SELF
Hello FixYa customer,
There can be different issues in the mechanism or electrical that will cause the unit to shut down. However, since the power is going off completely after the initial plug in I suspect the power supply.
The SMPS, Switch Mode Power Supply has filter components that age due to heat, the voltage output on the filters reduces until the Micro Processor malfunctions and the unit won't stay on. The power supply filters can be changed by an experienced technician for $10-$15.00 in parts plus labor.
Thank you
5/11/2010 2:36:01 AM • Sony SLV-R1000... • Answered on May 11, 2010
VHS loads and begins play - fuzzy lines
Hi
Have you tried a head cleaning tape in vcr as fault might be due to dirt on video head or on the acl head, if this does not clear fault video heads could be faulty is could be costley.
regards windyhouse
3/29/2010 10:41:37 PM • Sony SLV-R1000... • Answered on Mar 29, 2010
I have a Sony SLVR1000
parts are avil for this VCR, but u can't buy buuy the sound card, u have to id and repair the one u have, here is a link to site that has all the parts for this unit, u can call them and ask what u need to order.
http://www.partstore.com/Model/Sony/Sony/SLVR1000.aspx?SearchTerm=True
11/18/2009 8:52:08 PM • Sony SLV-R1000... • Answered on Nov 18, 2009
7answers
Can't get curennt year 2009
press the menu button on the panel for 5 seconds to go to format the new date settings.
1/11/2009 10:57:23 AM • Sony SLV-R1000... • Answered on Jan 11, 2009
VCR will not load nor play
CHeck the timer switch. It looks like a round, flat plastic wheel with 4-5 small tabs (Contacts) sticking out. Sometimes they get dirty and won't respond to inputs.
Jim
9/28/2008 6:29:47 AM • Sony SLV-R1000... • Answered on Sep 28, 2008
No picture
I assume this symptom appears when attempting to play a tape? If the picture is mostly snow, VCR may need video head cleaning. To do this, take the top cover off- You will note a cylindrical shiny aluminum drum- the actual heads are at the lower edge of this rotating drum.
Anyway, use a lint free cloth or special wipe moistened with rubbing alcohol, or product specifically made for such, carefully cleaning those heads as well as the drum itself. Occasionally, it may take 2 or 3 cleanings.
If the VCR has lots of hours, or abrasive head cleaners have been used, the head could be worn out. If so, toss the rig and purchase a new one. Head replacement is non-economical unless you have a high end machine.
6/12/2008 3:34:14 PM • Sony SLV-R1000... • Answered on Jun 12, 2008
Won't play or record.
This will be a bit difficult because I can't see the unit, but here are a few ideas.
1) Did the arms that pull the tape around the head go all the way around the heads? If not, I would look at the loading motor belt. It may be slipping and not fully loading the tape.
2) Is the tape being pressed up against the pinch roller on the right hand side of the deck? If not, there is a pivot arm that is supposed to pull the tape up to the pinch roller. This arm often gets stuck in the "loaded" position and therefore does not pull the tape up to the pinch roller.
Please update this with what you see and I'll provide more details on how to address the problem.
Dan
3/19/2008 5:02:30 PM • Sony SLV-R1000... • Answered on Mar 19, 2008
2answers
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
2/19/2008 5:42:36 PM • Sony SLV-R1000... • Answered on Feb 19, 2008
3answers
Vtr image
Try cleaning the Video Heads first.
5/30/2007 1:09:53 AM • Sony SLV-R1000... • Answered on May 30, 2007
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 11 hours ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered Yesterday
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony SLV-R1000 S-VHS VCR Logo
Popular Tags
21 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
need part back tension lever sony vcr
  • Televison & Video
