20 Most Recent Sony KP-61V45 61" Rear Projection Television Questions & Answers
You Do Not have a Lamp in this Model it is Projection and has 3 Tubes R/B/G Tubes
You need to Check the Hori output Transistor and a small blue capacitor 2k it is a high voltage capaciotr that feeds to the Hori output.
Their is No Tubes avilable for this model you have to ship Bad Tube and have it rebuilt, another thing if you had a Bad Tube which ever one is bad Set would come on with that color of drive lines across the TV.
Sony KP-61V45... • Answered on Jun 30, 2011
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Sony KP-61V45... • Answered on Nov 24, 2010
A power panel goes for about $200. You can get it from an electronic sgop that also deals in parts.
Take care
Sony KP-61V45... • Answered on Oct 10, 2010
The problem with the television is from the power panel of the television, it is receiving power but not getting it to the main panel of the television so as to power the screen that is why you are having the static sound from the speaker of the television.
Once you can replace the power panel of the television, your television will be in good condition once again. You can locate the power panel, it is the panel the power cable is connected to, so once you open up the back of the television, then trace the power cord to the panel it is connected to.
A replacement will do the job.
Take care
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sony KP-61V45... • Answered on May 25, 2009
If the IC's say have STK printed on them, then they are the convergence IC' s. should be three of them, replace all 3 , and the burned green coils, sometimes these burn as they supply the volts to the STK's. good luck, be safe..
Sony KP-61V45... • Answered on Mar 30, 2009
You need to replace STK4278-L quantity 2 on D board
Above part is available in part store.
Sony KP-61V45... • Answered on Mar 02, 2009
You have already diagnose the problem,the set has a loose conection in the high voltage area or horizontal drive circuits but dont be suprize if you find more loose conections or overheated areas,while you are looking for this loose conection giving you this problem take the time and correct any other questionable spot.If you are familiar with tv service this will give a place to start but if you are not too familiar be safe and call for assistance from a servicer,it should not be expensive.Let us know if youu need more help.
Sony KP-61V45... • Answered on Mar 01, 2009
hit the pip button again it should shut it off
Sony KP-61V45... • Answered on Jan 18, 2009
get the tv degaused that should fix the problem
Sony KP-61V45... • Answered on Jan 11, 2009
let me know the answer
Sony KP-61V45... • Answered on Jan 05, 2009
go to sonytv.com parts see if you can get one cheaper there.i dont know how old the tv is but dealing direct with sony should bring the cost down somewhat.or you may waant to advertise in the local paper and see if someone out there has one theyd sell cheap.
you need to replace the convergence board its around 80 dollars
Sony KP-61V45... • Answered on Aug 27, 2008
there is a convergence board in the back of the tv that needs replaced..my tv was doing the same thing and i rto be replaced the board and it works perfect now.the part should run under 100.00 and has to be soldered in place.
Sony KP-61V45... • Answered on Aug 17, 2008
around 400.00 would be fair pricing wise
take it in and have it repaired...its still relatively new and shouldnt be too much to repair..its ony 5 years old so get it fixed and it will be fine
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Sony KP-61V45... • Answered on Sep 20, 2006
Televison & Video Logo
22 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
turning off pip kp 61v45
  • Televison & Video
