20 Most Recent
Toshiba PDR-M71 Digital Camera Questions & Answers
Better Focus
There are several factors that can contribute to getting better focus and improved results.
1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds.
2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls.
3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus.
4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure.
5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button.
2) Press and Hold the DISP/i button to see the Manual Focus Range.
3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key.
4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture.
*Press the Focus Button to return to Auto Focus / Macro options
Getting accurate color
1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M")
2) Use the Arrow Down on the ENTER Button to select W/B (White Balance)
3) Press the center on the ENTER Button to select and adjust W/B (White Balance)
4) Use the Arrow Right (once), then Press and Hold the Arrow Down.
Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear.
5) Once PRE SET appears, Press the center of the ENTER Button to select it.
6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White".
7) Press the Shutter Button to program the new "True White" setting.
8) Press the center of the ENTER Button to accept and continue photography.
These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Choosing batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life:
NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges).
Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting.
Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed.
Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries.
Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
My Toshiba Camileo HD-DV Camcorder won't focus
If your Toshiba Camileo HD-DV camcorder is not focusing properly, there are a few potential causes and solutions to try:
- Check that the lens is clean and free from any smudges or fingerprints. Even a small amount of dirt or debris on the lens can affect the focus. If the lens is dirty, try cleaning it with a lens cleaning solution and a microfiber cloth.
- Make sure the lens is not blocked by any foreign objects, such as the hood of a camera bag or the edge of a cap.
- Try adjusting the focus manually using the focus ring on the lens. If the focus ring is not responding or is difficult to turn, the lens may need to be serviced.
- Make sure your camcorder firmware is up to date. Check Toshiba website to see if there is any update available and instructions on how to update.
- Make sure the camera is not in macro mode. Some cameras have a separate macro mode that enables the camera to focus on objects that are very close. If you are not trying to take close-up shots, you may need to switch out of this mode.
- Make sure the scene is well lit. Low light can make it more difficult for the camera to focus, try adding more light to the scene or use the manual focus.
If none of the above steps work, it is possible that the camera's autofocus system may be malfunctioning and will need to be repaired. It's best to contact Toshiba customer service or a local camera repair shop for a diagnosis and estimate for repair if the issue persists
I'm having a problem with
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
