20 Most Recent Toshiba PDR-M3 Digital Camera Questions & Answers
manual
No image appears
It could be that the video cable is being used for video output, so Disconnect the video cable.
9/15/2005 10:41:19 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
Nothing happens when I use the camera buttons and switches.
There could be 2 reasons for that: 1. Camera malfunction - Remove the battery or AC adapter once and retry. 2. The Mode dial has been moved to another setting - Remove the battery, re-insert them and try again.
9/15/2005 10:39:32 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
Erasing frames
The frame might be protected, so just Remove the frame protection.
9/15/2005 10:37:18 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
Dark playback image
It could be that the subject is too far away. so just Move closer to the subject.
9/15/2005 10:34:44 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
A flash problem
there could be a few reasons for that: 1. The Mode Dial has been moved to another setting - Set the Mode dial to the correct setting. 2. The flash is set to Suppressed Flash mode - Set the flash to Auto, Red-eye Reduction or Forced Flash mode. 3. You pressed the shutter button while the flash was charging - Wait until charging is complete before pressing the shutter button.
9/15/2005 10:32:53 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
Battery
there could be few reasons for that: 1. You are using the camera in extremely cold conditions - Put the battery in your pocket or another warm place to heat it and then load it into the cameras just before taking a picture. 2. The terminals are soiled - Wipe the battery terminals with a clean, dry cloth. 3. The battery has reached it's effective life - Load a new fully charged battery.
9/15/2005 10:29:04 AM • Toshiba PDR-M3... • Answered on Sep 15, 2005
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
9/11/2005 10:44:39 AM • Toshiba PDR-M3... • Answered on Sep 11, 2005
How does is the right setting of Toshiba refrigerator display setting
This is not a camera. Why post in the Camera queries forum ?
12/8/2021 11:25:12 AM • Toshiba Cameras • Answered on Dec 08, 2021
Toshiba tv 43u2963db
a) This is not a camera b) Have you looked in the manual ?
11/30/2019 12:00:25 PM • Toshiba Cameras • Answered on Nov 30, 2019
I have a Toshiba PDR2300. I get card error and can't take pictures. How do I fix this?
Discover what the error is with the card and correct it. The card could be corrupted, an incorrect storage capacity, write-protect could be set, or it could be full.
4/8/2017 12:00:53 AM • Toshiba Cameras • Answered on Apr 08, 2017
I'm having a problem with
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
3/10/2017 11:42:30 AM • Toshiba Cameras • Answered on Mar 10, 2017
I need a price check on a Toshiba CMOS digital still. Camera price check please
Fixya does not offer advice on pricing equipment. Check on Ebay to see how much similar items are being advertised for.
12/16/2016 9:14:30 PM • Toshiba Cameras • Answered on Dec 16, 2016
Ineedtoget my Toshiba TV and my digital stream converterbox
You need to get them to do what, exactly ? Dance ? Make coffee ? Breed ? Can you be more specific, please ?
11/11/2016 11:25:56 AM • Toshiba Cameras • Answered on Nov 11, 2016
Toshiba PDR-M3 Digital Camera Logo
7 questions posted
Top Toshiba Cameras Experts
Lawrence Oravetz
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
View Most Popular
Toshiba Cameras
  • Toshiba Cameras
Most Popular Question
no image appears
  • Cameras
