20 Most Recent Sony KP-EF61 61" Rear Projection Television Questions & Answers
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
Sony KP-EF61 61"... | Answered on Oct 06, 2018
Had this problem bout 2,3 years ago...it was fixed in about 5 minutes with the help of this article
Tonight I have to do this fix again..the blue lines came back about a week.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I strongly urge you to save the web page locally on your hard drive or print it out and place with the tv manual....
Good Luck..
Sony KP-EF61 61"... | Answered on Dec 02, 2013
If its over 7 years old the board will not be available from Sony. If you would care to describe what the set is doing or not I will try to help you.
Sony KP-EF61 61"... | Answered on Dec 05, 2012
drrwk,
You have bad convergence ICs or circuitry. It is not that difficult to repair if you are good with tools, can solder well and are meticulous with detail. If you feel that you could handle this I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will walk you through the procedure as well as where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Sony KP-EF61 61"... | Answered on Nov 30, 2010
try http://www.eserviceinfo.com/searchads.php?searchstring=kp-ef&model=KP-EF61HK&model_id_click=M17461878
Sony KP-EF61 61"... | Answered on Mar 19, 2008
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sony Televison &... | Answered Yesterday
Hello
Blu-Ray players' region hack proceedings are yet to come.
Sony Televison &... | Answered on Jun 24, 2020
It won't work as it has a different size screen and will produce the wrong size picture, if it works at all.
Sony Televison &... | Answered on Jun 19, 2020
google unit or call sony tech support
Sony Televison &... | Answered on Jun 08, 2020
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site either in Web View, on a mobile; or by a desktop PC. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony Televison &... | Answered on May 28, 2020
Sony KP-EF61 61" Rear Projection Television Logo
9 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony powersuply circuit boad
  • Televison & Video
