20 Most Recent Toshiba PDR-M11 Digital Camera Questions & Answers
Use the resolution button on the top of the camera by the LCD display. One button is for selecting Flash. One button is for the self-timer. The middle button is for resolution. Press the button repeatedly to cycle through the options.
Toshiba PDR-M11... • Answered on Sep 15, 2005
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 4. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Toshiba PDR-M11... • Answered on Sep 11, 2005
a) This is not a camera b) Have you looked in the manual ?
Toshiba Cameras • Answered on Nov 30, 2019
Discover what the error is with the card and correct it. The card could be corrupted, an incorrect storage capacity, write-protect could be set, or it could be full.
Toshiba Cameras • Answered on Apr 08, 2017
As you yourself have said, this is NOT a camera. For help, I would advise you to post this in a forum dealing with computer equipment.
Toshiba Cameras • Answered on Mar 10, 2017
Fixya does not offer advice on pricing equipment. Check on Ebay to see how much similar items are being advertised for.
Toshiba Cameras • Answered on Dec 16, 2016
You need to get them to do what, exactly ? Dance ? Make coffee ? Breed ? Can you be more specific, please ?
Toshiba Cameras • Answered on Nov 11, 2016
Look in the front of your phone directory to find out how to do call forwarding in your area, or call land line phone company and ask them.
Toshiba Cameras • Answered on Nov 02, 2016
Toshiba PDR-M11 Digital Camera Logo
7 questions posted
Top Toshiba Cameras Experts
Lee Hodgson
Lee Hodgson
Lawrence Oravetz
Harrie
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
View Most Popular
Toshiba Cameras
  • Toshiba Cameras
Most Popular Question
resolution
  • Cameras
