20 Most Recent Sony KP-53V85 53" Rear Projection Television Questions & Answers
2answers
My connection for the cable on the back of my tv is broken!
If you have RCA inputs for video and sound their will be a white and red which is audio and yellow is video. If you have a cable box that you use to change channels, this should have the RCA outputs for your audio and video. You will also have to set your tv to select that input to get the cable. Hope this helps
4/17/2013 4:03:30 AM • Sony KP-53V85... • Answered on Apr 17, 2013
Red standby button lit but black screen and no sound?
Google model # look for service manual. Depending on the number of blinks, it will help you isolate problem.
4/22/2012 12:15:41 AM • Sony KP-53V85... • Answered on Apr 22, 2012
Im' from Mexico i
$500 dollars in good working order sold as used tv.
8/4/2011 10:34:55 PM • Sony KP-53V85... • Answered on Aug 04, 2011
No, LED is not lit or blinking when I press Power.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem....
11/29/2010 4:59:27 PM • Sony KP-53V85... • Answered on Nov 29, 2010
Tv has a red screen. can hear sound but that is
u have bad red picture tube, parts no longer avelible
8/26/2010 2:26:51 AM • Sony KP-53V85... • Answered on Aug 26, 2010
The 3 colours are off center not aligned properly,
replace convergence ICs but dont try to realign befor replacing as it will align wrong and its a very long process to realign, if it is a very old unit check out ebay as they are going cheap second hand mite be cheaper to buy another
5/7/2010 5:15:40 AM • Sony KP-53V85... • Answered on May 07, 2010
Sony KP53v85 T.V (52
the problemthat i am having with my sony projection tv kp53v85 is that the sound keeps cutten off and on
3/2/2010 8:38:41 PM • Sony KP-53V85... • Answered on Mar 02, 2010
I have a kp53v85 and the sound cuts out then comes
same problem
3/2/2010 8:29:01 PM • Sony KP-53V85... • Answered on Mar 02, 2010
The screen is fuzzy and blurry, almost 3Dish.
This is convergence out chip failure that you see 3D look picture in TV.
Replace IC1502 on G Board, it is big black chip and number would be STK392-150 to fix red convergence issue.
Required chip is available in Part Store for $28
Please do not play with service data as any wrong button push on remote will create trouble in tv picture settings.
Hope this info will help you.
Thanks.
2/14/2010 1:58:06 AM • Sony KP-53V85... • Answered on Feb 14, 2010
Stand By/Timer Flashing 4 Times
It means that there is a horizontal sweep or High voltage circuit falure. It is a high voltage circuit and only a trained tech should attempt to repair these sets. A TV set is not a place to be experimenting inside of.
5/17/2009 6:44:19 PM • Sony KP-53V85... • Answered on May 17, 2009
2answers
Double vision with redness
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
2/22/2009 11:20:38 PM • Sony KP-53V85... • Answered on Feb 22, 2009
Picture doesnt look as clear as before.
If the colors are mis-aligned or letters are out of focus, you may need to repair. For mis-alignment you can push the flash-focus button on the front to autoconverge the colors. Replacing the CRTs would cost a fortune. If the picture has just degraded in brightness and clarity, you cold clean it out. You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
12/8/2008 3:50:56 AM • Sony KP-53V85... • Answered on Dec 08, 2008
KP-53V85 SONY PIC DOESNT LOOK AS CLEAR AS BEFORE.
Clean mirror and lamp lenses with a good glass cleaner (mild) but never put glass cleaner on your screen! dust can be the simple cause also focus it
12/8/2008 3:43:16 AM • Sony KP-53V85... • Answered on Dec 08, 2008
Sony KP-53V85
My unit is 9 years old, almost 10 (in 2 months) and started the same a couple of months ago. The only way to fix it is to have them serviced by a tech and replace the projectors. Its just the age/use of the unit catching up with it.
Many resellers sold them with an offer to sell you an optional maintence service where they would fix/clean/replace the projectors for upto 5 years after purchase. I'm not sure if they even have the parts anymore since these tv's are no longer produced. After market repairs are likely to cost as much as or nearly as much as buying a new flat screen tv.
12/4/2008 9:41:47 PM • Sony KP-53V85... • Answered on Dec 04, 2008
Sony KP-53V85 53" Rear Projection Television Logo
41 questions posted
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
connection cable back tv broken
  • Televison & Video
