20 Most Recent Sony RM-Y128 Remote Control Questions & Answers
What is the brand name to your DVD player? Provide more details please. If you wish to get setup codes, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sony RM-Y128... | Answered on Oct 05, 2013
I was able to solve the problem by trying every device available on the TV set's Menu until I got it to work.
Sony RM-Y128... | Answered on Dec 03, 2008
if you give me the make and what you want the codes for ie tv dvd etc but usually on the controll their is a set button or s
1 switch on item you want ie tv or dvd
2 press and hold s or set button
3 whilst holding down this button prss n releasep or power button
4 release s or set
5 press component button
6 now either enter code using key pad or press ch+ button once
7 if you have the code press enter if you dont press power button if the controll dont work the telly or dvd press the ch+ button again then try the power again you can do this upto 70 times but when the controll affects the item press then enter button to store this setting if you let me know what make and waht you want i can get you the codes hope this is some help
Sony RM-Y128... | Answered on Sep 15, 2008
First turn on device to be programmed. Press what device you want to program (tv) hold it down and at the same time hold power button down. Wait for red light to shut off and come back on. When light comes on remove finger device button and continue to hit power button on & off until device shuts off. Then hit stop button on the bottom off remote.
Sony Televison &... | Answered on Aug 04, 2020
Take it to a Sony Service Centre to save your money and get it fixed properly.
Sony Televison &... | Answered on Jul 20, 2020
If the screen of your TV is black and nothing is displayed, see the FAQ below: No picture on the TV screen.
When using a TV with the Self Diagnostics option, try the Self Diagnostics test. For details, refer to the following Q&A: How to use the Self Diagnostics option.
Sony Televison &... | Answered on Jul 13, 2020
Are you a television engineer? Do you have all the test equipment? Normal people can't repair their own televisions. Do you know that the main board you put in was a good one and not out of a scrapped set? Can you send it back and ask for another one? Taking it to a television engineer is by far the cheapest way to fix. Or you can change all the boards, but make sure you buy them from the manufacturer and not Jimmy. Change all the boards before you turn on the power to avoid 'domino effect', one bad board kills all the other boards attached to it.
Sony Televison &... | Answered on Jul 09, 2020
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sony Televison &... | Answered on Jul 01, 2020
Hello
Blu-Ray players' region hack proceedings are yet to come.
Sony Televison &... | Answered on Jun 24, 2020
It won't work as it has a different size screen and will produce the wrong size picture, if it works at all.
Sony Televison &... | Answered on Jun 19, 2020
google unit or call sony tech support
Sony Televison &... | Answered on Jun 08, 2020
Sony RM-Y128 Remote Control Logo
4 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
get sony dvd player work
  • Televison & Video
