20 Most Recent
Sony HT-DDW740 System Questions & Answers
Two of my speakers (one front and one surround)
If there is a problem with the receiver itself you would want to have it serviced/repaired. Or consider replacing it. You could get a used or new 5.1 receiver for quite cheap. Most times much cheaper then the cost of repair. I assume you switched out another speaker and the same noise came from that speaker and that is why you assume its the receiver. If you need further assistance please let me know.
Thank you,
Lee
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Sony HT-DDW740 Tuner Hum
Hi:
On the stanby power supply replace or have replaced C899 with a 100uf 35V capacitor, this capacitor goes bad and produces hum in the supply voltage to the AM FM circuits.
