20 Most Recent Sony DAV-FR10W System Questions & Answers
Have a sony home theater system model davfr10w but the receiver is jumping from sat which is where Iwant if to dvd??? Can anyone give some input on this problem Thanks
I have the same problem. Purchased mine in 2005....went out in 2010. My Sonny dealer could not fix. They talked to Sony and they wanted $230to repair with no warranty. I'm trying to find a replacement but no luck.
12/14/2012 9:08:38 PM • Sony DAV-FR10W... • Answered on Dec 14, 2012
0answers
No sound from sony dav-fr10w
First thing to check is the simple solution. Make sure you have the positive and negative hooked up correctly and also make sure that the wire ends are bared enough and that you have good clean contact in the snap terminal.
6/16/2011 2:57:54 AM • Sony DAV-FR10W... • Answered on Jun 16, 2011
The system turns on for about 5 seconds and then
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
2/27/2011 10:59:11 PM • Sony DAV-FR10W... • Answered on Feb 27, 2011
Getting a loud hum only from video function.
Check your connections. Chances are you may have crossed the RED video cable and the RED audio cable.
2/26/2011 1:30:15 AM • Sony DAV-FR10W... • Answered on Feb 26, 2011
I want to set up my dav-fr10w to 'interlace'
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
2/5/2010 11:26:59 AM • Sony DAV-FR10W... • Answered on Feb 05, 2010
2answers
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
4/25/2009 7:59:32 AM • Sony DAV-FR10W... • Answered on Apr 25, 2009
Can the speakers be used with other Receiver?
Yes you can use the speakers and also the sub if it is a powered sub with a phono input,but be aware they are nowere near good enough for the Onkyo 706,look at the JAMO 102 sub and sats as a starting point if you have a small room,say 4meters x 5meters,or somthing from other good speaker companys to make the most of what is a hard hitting amp,but if you must use the speakers you have set the cross over to about 120hrtz to save the main speakers getting to much bass .
Hope this helps.
CABLE GUY.
4/20/2009 6:38:11 PM • Sony DAV-FR10W... • Answered on Apr 20, 2009
Sony universal remote will not operate sony dream system
Solution is to buy Sony original remote for DAV-FR10W system from Sony Accessories Store under following part number..
147869811 RM-SP350 REMOTE CONTROL
2/5/2009 7:10:52 PM • Sony DAV-FR10W... • Answered on Feb 05, 2009
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
12/16/2007 4:10:40 PM • Sony DAV-FR10W... • Answered on Dec 16, 2007
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
6/11/2007 12:35:18 AM • Sony DAV-FR10W... • Answered on Jun 11, 2007
How to reset a sony str-av480 receiver
To reset a Sony STR-AV480 receiver, you can follow these steps:
1. Turn off the receiver.
2. Press and hold down the power button on the front panel of the receiver.
3. While holding down the power button, press the "Enter" button on the front panel of the receiver.
4. Keep holding down both buttons for a few seconds until "Clearing" appears on the front display panel of the receiver.
5. Release both buttons and wait for the receiver to turn off.
6. Turn on the receiver and it should be reset to its default settings.
Note that performing a reset will erase all custom settings and return the receiver to its factory default settings. If you have any custom settings that you want to keep, make sure to write them down before performing the reset.
3/14/2023 3:49:00 PM • Sony Audio... • Answered on Mar 14, 2023
Display not working anymore
3/5/2023 10:14:01 AM • Sony Audio... • Answered on Mar 05, 2023
I have a Sony Dav Fx888k DVD HOME THEATER System, It's a 5 disc changer. I am unable to insert the CD. It displays C 31 00.
The error code C 31 00 on Sony DVD Home Theater System usually indicates a mechanical issue with the disc changer mechanism. Here are some steps you can try to resolve the issue:
  1. Turn off the power to the DVD Home Theater System and unplug it from the wall outlet.
  2. Wait for a few minutes, then plug the system back in and turn it on.
  3. Press the "Eject" button on the remote or the unit to try to eject the disc tray.
  4. Gently try to move the disc tray by hand to see if it is stuck or obstructed.
  5. If the disc tray does not move, or if you hear any unusual noises, it may indicate a more serious mechanical issue that requires repair.
If none of these steps resolves the issue, it's recommended to contact Sony customer support or a qualified technician for further assistance.
2/26/2023 5:13:16 PM • Sony Audio... • Answered on Feb 26, 2023
Sony wireless headphones have static...why?
The static you're experiencing with your Sony wireless headphones can be caused by various factors, including interference from other electronic devices, radio frequency congestion, and distance from the transmitter. Here are some things you can try to minimize the static: Move the transmitter closer to your headphones: The closer your headphones are to the transmitter, the stronger the signal will be and the less static you will hear. Reduce interference: Try turning off any other electronic devices that may be causing interference, such as microwaves, wireless routers, and cordless phones. If possible, move the transmitter away from these devices. Change channels: Some wireless headphones have multiple channels to choose from. Try changing the channel to see if that reduces the static. Check the batteries: Make sure the batteries in your headphones are fully charged or replaced if necessary. Reset the headphones: Sometimes resetting the headphones can help eliminate static. Refer to the user manual for instructions on how to reset your specific model. Contact Sony customer support: If none of these solutions work, you may want to contact Sony customer support for further assistance or consider getting a replacement if your headphones are still under warranty.
2/26/2023 6:44:58 AM • Sony Audio... • Answered on Feb 26, 2023
2answers
I have a Sony music system mch rv6 problem is not a turn powering on and power bottom light is on please help me
There could be several reasons why your Sony music system is not turning on. Here are a few things you can try:
  1. Check the power source: Make sure that the power source is properly connected and that there is electricity flowing through it.
  2. Check the power cord: If the power source is connected, then the problem may be with the power cord. Try using a different power cord to see if it makes a difference.
  3. Check the fuse: If the power cord is working properly, then the problem may be with the fuse. Locate the fuse in the system and replace it if it's blown.
  4. Reset the system: If the above steps don't work, try resetting the system. To do this, unplug the power cord from the wall outlet, wait for a few minutes, and then plug it back in.
  5. Contact Sony Support: If none of these steps solve the issue, it may be a hardware problem. In this case, you may need to contact Sony Support for further assistance. They can guide you through the next steps, which may include repair or replacement of the system.
Please note that these are general troubleshooting steps, and the exact steps you need to take may vary depending on your specific system model.
2/13/2023 12:02:28 PM • Sony Audio... • Answered on Feb 13, 2023
Sony DAV-FR10W System Logo
20 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
  • Audio Players & Recorders
