20 Most Recent Zyxel Prestige 310 (AM406100) Router Questions & Answers
2answers
What is the default user name and password to login the Prestige via the browser?
To restrict only the adminstrator can configure the router, there is a login procedure prompted for asking User Name and Password. The default User Name is 'admin' and the default password is the default SMT password, '1234'.
1/24/2009 10:02:45 AM • Zyxel Prestige... • Answered on Jan 24, 2009
My P310 can not get an IP address from the ISP to connect to the Internet, what can I do?
Currently, there are various ways that ISPs control their users. That is, the WAN IP is provided only when the user is checked as an authorized user. The ISPs currently use three ways: 1. Check if the 'MAC address' is valid 2. Check if the 'Host Name' is valid, e.g., @home 3. Check if the 'User ID' is valid, e.g., RR-Toshiba Authentication Service, RR-Manager Authentication Service, RR Telstra If you are not able to get the Internet IP from the ISP, check which authentication method your ISP uses and troubleshoot the problem as described below.
2/19/2006 4:49:10 PM • Zyxel Prestige... • Answered on Feb 19, 2006
How fast can the data go?
The speed of the cable modem is only one part of the equation. There are a combination of factors starting with how fast your PC can handle IP traffic, then how fast your PC to cable modem interface is, then how fast the cable modem system runs and how much congestion there is on the cable network, then how big a pipe there is at the head end to the rest of the Internet. Different models of PCs and Macs are able to handle IP traffic at varying speeds. Very few can handle it at 30 Mbps. Ethernet (10baseT) is the most popular cable modem interface standard for the PC. This automatically limits the speed of the connection to under 10 Mbps even if the cable modem can receive at 30 Mbps. Most Local Area Networks use 10baseT Ethernet, and although they are 10 Mbps networks, it takes a LOT longer than one second to transmit 10 megabits (or 1.25 megabytes) of data from one terminal to another. Cable modems on the same node share bandwidth, which means that congestion is created when too many people are on simultaneously. One user downloading large graphic or video files can use a significant portion of shared bandwidth, slowing down access for other users in the same neighborhood. Most independent Internet Service Providers today connect to the Internet using a single 1.5 Mbps "T1" telephone line. All of their subscribers share that 1.5 Mbps pipeline. Cable head-ends connecting to the Internet backbone using a T1 limit their subscribers to an absolute maximum of 1.5 Mbps. To create the appearance of faster network access, service companies plan to store or "cache" frequently requested web sites and Usenet newsgroups on a server at their head-end. Storing data locally will remove some of the bottleneck at the backbone connection. How fast can they go? In a perfect world (or lab) they can receive data at speeds up to 30 Mbps. In the real world, with cost conscious cable companies running the systems, the speed will probably fall to about 1.5 Mbps.
2/19/2006 4:48:26 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What DHCP capability does the P310 support?
The Prestige 310 supports DHCP client on the WAN port and DHCP server on the LAN port. The Prestige's DHCP client allows it to get the Internet IP address from ISP automatically. The Prestige's DHCP server allows it to automatically assign IP and DNS addresses to the clients on the local LAN.
2/19/2006 4:47:40 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What is the main difference between WinGate and the Prestige 310 ?
# WinGate is a software only solution that needs to be installed in a dedicated Windows 95 PC based server. The total cost and complexity are many times over ATI?s product. The Prestige 310 Internet Access Sharing Router is a plug-n-play internet appliance. # WinGate requires all TCP/IP applications such as Netscape Navigator to be reconfigured to have the dedicated server as a proxy. The Prestige 310 Internet Access Sharing Router does not require users to reconfigure any software at all. # The Prestige 310 Internet Access Sharing Router uses Network Address Translation (NAT) scheme, which supports all TCP/UDP ports. WinGate only supports limited number of ports, such as http(80), ftp(21), telnet(23), and pop3(110). # WinGate works as a proxy, while the Prestige 310 Internet Access Sharing Router works as a gateway. The gateway approach is more efficient than the proxy during the processing of TCP/IP commands. As a result, the Prestige 310 Internet Access Sharing Router achieves 10% to 20% higher performance than that of software solutions such as WinGate. # The Prestige 310 Internet Access Sharing Router uses Solid State Disk technology. There are no moving parts in the product. It is much more reliable than any hard disk based system, such as the one for WinGate.
2/19/2006 4:46:59 PM • Zyxel Prestige... • Answered on Feb 19, 2006
How does e-mail work through the Prestige 310 ?
It depends on what kind of IP you have: Static or Dynamic. If your company has a domain name, it means that you have a static IP address. Suppose your company's e-mail address is [email protected]. Joe and Debbie will be able to send e-mail through Prestige 310 Internet Access Sharing Router using [email protected] and [email protected] respectively as their e-mail addresses. They will be able to retrieve their individual private and secure e-mail, if they have been assigned the proper access right. If your company does not have a domain name, it means that your ISP provides you with a dynamic IP address. Suppose your company's e-mail address is [email protected]. Jane and John will be able to send e-mail through Prestige 310 Internet Access Sharing Router using "jane" and "john" respectively as their e-mail addresses. Again, they will be able to retrieve their individual private and secured e-mail, if they have been assigned the proper access right.
2/19/2006 4:46:21 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What is the difference between the internal IP and the real IP from my ISP?
Internal IPs are sometimes referred to as virtual IPs. They are a group of up to 255 IPs that are used and recognized internally on the local area network. They are not intended to be recognized on the Internet. The real IP from ISP, instead, can be recognized or pinged by another real IP. The Prestige 310 Internet Access Sharing Router works like an intelligent router that routes between the virtual IP and the real IP.
2/19/2006 4:45:49 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What is BOOTP/DHCP?
BOOTP stands for Bootstrap Protocol. DHCP stands for Dynamic Host Configuration Protocol. Both are mechanisms to dynamically assign an IP address for a TCP/IP client by the server. In this case, the Prestige 310 Internet Access Sharing Router is a BOOTP/DHCP server. Win95 and WinNT clients use DHCP to request an internal IP address, while WFW and WinSock clients use BOOTP. TCP/IP clients may specify their own IP or utilize BOOTP/DHCP to request an IP address.
2/19/2006 4:45:15 PM • Zyxel Prestige... • Answered on Feb 19, 2006
Does Prestige 310 support dynamic IP addressing?
The Prestige 310 supports either a static or dynamic IP address from ISP.
2/19/2006 4:44:41 PM • Zyxel Prestige... • Answered on Feb 19, 2006
How can I manage the Prestige 310 ?
# Menu driven user interface for easy network management Local and remote console management # Windows configurator Telnet remote management # TFTP (Trivial File Transfer Protocol) firmware upgrade and configuration backup and restore
2/19/2006 4:44:02 PM • Zyxel Prestige... • Answered on Feb 19, 2006
Which Internet Applications can I use with the Prestige 310 ?
Most common applications includes MIRC, PPTP, ICQ, Cu- SeeMe, NetMeeting, IP/TV, RealPlayer, VDOLive, Quake, Quake11, Quake111, StarCraft, & Quick Time.
2/19/2006 4:43:22 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What is PPPoE?
PPPoE stands for Point-to-Point Protocol Over Ethernet that is an IETF draft standard specifying how a computer interacts with a broadband modem (i.e. xDSL, cable, wireless, etc.) to achieve access to the high-speed data networks via a familiar PPP dialer such as 'Dial-Up Networking' user interface. PPPoE supports a broad range of existing applications and service including authentication, accounting, secure access and configuration management. There are some service providers running of PPPoE today. Before configuring PPPoE in the Prestige, please make sure your ISP supports PPPoE.
2/19/2006 4:41:53 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What do I need to use the P310?
You need a ADSL modem or cable modem with an Ethernet port to use the P310. The P310 has two Ethernet ports: LAN port and WAN port. You should connect the computer to the LAN port and connect the external modem to the WAN port. If the ISP uses PPPoE or RoadRunner Authentication you need the user account to enter in the P310.
2/19/2006 4:39:16 PM • Zyxel Prestige... • Answered on Feb 19, 2006
What is the Prestige 310 Internet Access Sharing Router?
The Prestige 310 Internet Access Sharing Router is a robust solution complete with everything needed for providing Internet access to multiple workstations through your cable or ADSL modem. The router equipped with 10Mbps Ethernet WAN port and an auto-sensing 10/100Mbps Etherent LAN port is the most simple and affordable solution for multiple and instant broadband Internet access. Virtually all-popular applications over Internet, such as Web, E-Mail, FTP, Telnet, Gopher, are supported. The Prestige 310 is designed for SOHO, branch offices, workgroups, and educational users.
2/19/2006 4:37:58 PM • Zyxel Prestige... • Answered on Feb 19, 2006
Can I use a Zyxel VMG3625-T20A router as a range extender?
Question edited for correct name of maker, add a few capitals. Question moved to Zyxel Router. There is some advice here. https://forums.techguy.org/threads/solved-how-do-i-bridge-my-router.1144390/ https://www.google.com/search?q=use+a+Zyxel+VMG3625-T20A+router+as+a+range+extender ..
3/31/2022 9:08:13 PM • Zyxel Computers... • Answered on Mar 31, 2022
I cannot log into my ZYXEL VMG3625-T20A router admin panel after changing access password
google router and forgot password or locked out
1/7/2020 4:26:12 PM • Zyxel Computers... • Answered on Jan 07, 2020
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next? Login to Your ZyXEL Router Using the Router Password Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: =============== Forgot Router Password? If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings. What should you do? Login to Your Router Using the Default Router Password Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides. Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!) Find Your Default Router Password Simply select your router manufacturer from the list below to display the default router passwords and usernames.
8/3/2019 7:47:05 AM • Zyxel Computers... • Answered on Aug 03, 2019
Zyxel Prestige 310 (AM406100) Router Logo
Popular Tags
15 questions posted
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zyxel Computers & Internet
Most Popular Question
difference between internal ip real ip
  • Computers & Internet
