20 Most Recent
Sony CASSETTE DECK Single Dual Cassette Deck Questions & Answers
Who sells drive- belts?
They are sold at Consolidated Electronics if you know the size and type otherwise you buy a kit from Marrs Communications
Aiwa model ad3100u
Marrs Communications is all you need to know about getting the right belts but putting them in is another subject.
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Where can i find a sony dual cassette deck tc-w490 manual
Hi,I can give you this
link. You can download the service manual of this Sony. I hope it will be usable for you.When you get to the site using the link it is possible that you have to wait a little bit to be able to download.After waiting you should see a button as "Get Manual" and simply click on it and save the file.Thanks.gylacz
Belt change
You will need a service manual for that model. Task not recommended for novice -- take to pro/tech
