20 Most Recent Sony MHC-GS300AV CD Shelf System Questions & Answers
Something has happened to it. Might be an IC fault. Seek assistance of any experienced service technician.
Sony MHC-GS300AV... | Answered on Jun 08, 2012
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sony MHC-GS300AV... | Answered on Jun 19, 2011
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Sony MHC-GS300AV... | Answered on May 11, 2011
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Sony MHC-GS300AV... | Answered on Feb 22, 2011
I would say 'something' in the transport is malfunctioning. It could be laser or mechanical but being intermittent may be very hard to pinpoint even for a technician. It may not be what we call 'economically repairable'.
I had an old Techincs SL-P3 in the 80's that did the same thing as yours - very random. I never resolved it.
Is there and pattern, say, xx:xx minutes/seconds into the disc? Since discs are written from the center out to the edge there could be a mechanical bind in the laser tracking mechanism. I doubt the laser itself is defective as they either work or don't (it is a diode after all) and don't self-resurrect.
If the CD is dying you could pick up a stand-alone player and use it instead. That way you still have the rest of the sound system.
Sony MHC-GS300AV... | Answered on Jun 09, 2010
buy a universal remote (with it you can control almost every device that has a remote).
Sony MHC-GS300AV... | Answered on Apr 07, 2010
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Sony MHC-GS300AV... | Answered on Apr 15, 2009
The audio amplifier IC are fried and need to be replaced
Sony MHC-GS300AV... | Answered on Mar 12, 2009
The audio amplifier IC is damaged and need to be replaced
Sony MHC-GS300AV... | Answered on Feb 11, 2009
Always be solved replace him the audio amplifier IC
No that is not really possible with this system nor would I recommend using it to record. What is it you are trying to record?
Thanks,
Lee
Sony MHC-GS300AV... | Answered on Jun 30, 2008
This Problem needs an expert Technician: Your problem is due to a missing Voltage around -30 volts that supplies the screen Processor. It could be an open low value resistor or defective switching transistor. Good Luck Toufic Malek
Sony MHC-GS300AV... | Answered on Sep 25, 2007
This is an electret condenser microphone which isn't a standalone self-energising device and needs a small amount of power and a couple of other components to produce a working device.
It is possible the Sony microphone might have some, all or none of those built into the package and this will have to be investigated.
The power requirement is typically 2 - 3 volts.
http://www.learningaboutelectronics.com/Articles/Electret-microphone-circuit.php
Sony Audio... | Answered on Oct 14, 2020
Sony MHC-GS300AV CD Shelf System Logo
Popular Tags
18 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
water damage power protect
  • Audio Players & Recorders
