20 Most Recent
Aiptek DV-3500 / DV5 Digital Camera Questions & Answers
Ican not transfer my photos from camera to PC.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
My aiptek camcoder is not
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
Aiptech dv3500
go to the Aipteck home page then to the dv3500 page drivers are there.
Flash is not working:
Hi , try to test the flush bulb by multi tester if reading display okey/if not reading replace flush bulb .
Wedding Memories May Be Gone
Congratulation on your wedding.
To your posted concern, do a Google for freeware memory card recovery software. You may need to use a memory Card Reader attached by USB to a PC to be able to do this.
I have had very good experiences with
GetDataBack though it is not free.
Good luck and kind regards.
No USB
It looks like this unit has a video out to a t.v. or vcr hookup. What you can do is download it to a vcr [ record it ] and pickup a vido frame grabber, what you are going to do is snag the photos from the video tape after recording them on tape. This is the only way unless you wish to tear up the unit; desolider the chip and using software retrieve the photos. If you are good with a solidering iron; digi key sells the usb port you woll need to replace.
www.digikey.com
