20 Most Recent Sony MHC-RX70 Shelf System Questions & Answers
Looking for a new drive
6/23/2014 2:27:29 PM • Sony MHC-RX70... • Answered on Jun 23, 2014
CD tray now operates perfect after belts replaced, but won't read CD's
Try 1st: You can take a q-tip dipped in alcohol (not dripping), rub the lens and gently blow it off with canned air. This will remove dust from under the lens as well. I don't recommend "lens cleaner CD's" that you can purchase as they sometimes rip of the lens. Try 2nd: If the CD does not spin up to the proper speed, it is the motor that spins the disk. This can be temporarily fixed by disconnecting the motor wires and using a 9 volt battery to spin the motor in each direction. The trick is to reverse the direction while it is still turning in the opposite direction. This will hopefully burn off the carbon and debris in the motor contacts.
4/12/2014 5:10:27 PM • Sony MHC-RX70... • Answered on Apr 12, 2014
0answers
2answers
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
1/5/2013 6:04:03 PM • Sony MHC-RX70... • Answered on Jan 05, 2013
My speaker outputs, including headphones, makes a loud pulsing sound. the stereo is a sony mhc-rx70 bookshelf system.
It is mobile phone system's problem, you can try to mobile phone shop where to install system. Instead of Stereo Earphone problem.
9/13/2012 2:26:36 AM • Sony MHC-RX70... • Answered on Sep 13, 2012
2answers
Sony rx70 3 cd changer
I also have exactly the same problem with the volume control. I was hoping to resolve the problem by doing some internal cleaning but seems like johanknopper tried it before.
I was thinking of buying a remote control separately as I lost mine in relocations. Found a second hand on-line but I am not sure if they all have the same frequency and if it works with mine.
Any Ideas?
9/25/2011 7:48:48 AM • Sony MHC-RX70... • Answered on Sep 25, 2011
0answers
0answers
0answers
My sony rx 70 shelf
Either the display, the traces (usually ribbon connectors), the power to the board/display, or the support chip could be bad. I would call Sony support (parts) and tell them you need a new display, and see what they can do. You would pretty much need a schematic to troubleshoot this problem for sure, but sometimes you can reseat a ribbon connector or resolder some cracked traces if you tear into the unit and inspect it carefully.
Sometimes the price of parts/boards deters people from fixing the unit, and just living with it.
Perhaps Sony will be an option, give it a try. Here's their contact site for parts:
http://esupport.sony.com/US/perl/model-accessories.pl
Good luck, and hope this helps.
10/8/2010 12:39:42 AM • Sony MHC-RX70... • Answered on Oct 08, 2010
0answers
Clicking Noise and sound coming in and out!
The speaker outlet connectors are very close to each other - if there is a short circuit between L & R channel terminals his will cause exactly the symptoms you describe when volume is increased
2/13/2009 11:21:54 PM • Sony MHC-RX70... • Answered on Feb 13, 2009
3answers
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier? You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505 Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations I hope you have my comments Greetings Franco Dosil Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505? Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505 Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505 Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas Espero que te sirvan mis comentarios Saludos Franco Dosil https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
4/22/2024 2:47:35 PM • Sony Audio... • Answered Yesterday
The display does not work on my Sony CDP-CE375 CD Player.
troubleshoot the issue: Reset the CD Changer: Turn off the CD player. Press the CLEAR button. Simultaneously, press and hold down the POWER button on the CD player for 60 seconds. If this doesn't resolve the issue, proceed to the next step. Check for Error Messages: If you encounter difficulty playing a disc and receive any of the following error messages, there may be an incorrect setting or a problem with the disc: NO DISC DISC ERROR CD ERROR TOC ERROR Refer to the instructions supplied with your CD player to verify model-specific information and troubleshoot the issue. Internal Component Repair: If the display issue persists, it might be related to an internal component that requires repair.
4/21/2024 5:40:21 PM • Sony Audio... • Answered Yesterday
20 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
clicking noise sound coming in out
  • Audio Players & Recorders
