20 Most Recent Sony STR-DE345 Receiver Questions & Answers
I have a sony reciever STR-DE345 that had some
Shorted output transistors.
6/3/2018 5:48:14 AM • Sony STR-DE345... • Answered on Jun 03, 2018
2answers
Sony str-de345 this keeps on making a
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
6/4/2016 12:06:02 AM • Sony STR-DE345... • Answered on Jun 04, 2016
2answers
My sony STR-DE345 amp says "protect" and there is
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
6/3/2016 11:53:38 PM • Sony STR-DE345... • Answered on Jun 03, 2016
2answers
I need a schematic or service manual for Sony STR-DE345.
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
12/12/2015 3:11:01 AM • Sony STR-DE345... • Answered on Dec 12, 2015
2answers
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
12/28/2013 1:19:06 AM • Sony STR-DE345... • Answered on Dec 28, 2013
0answers
2answers
HI DOING AN OIL CHANGE ON A 2004 YAMAHA WR 450 .
your a ****
1/15/2013 9:15:20 PM • Sony STR-DE345... • Answered on Jan 15, 2013
My unit powers up and then goes to protect, why?
This usually means there is a short in the amp section. It needs to be looked at by a pro.
12/26/2012 9:09:00 PM • Sony STR-DE345... • Answered on Dec 26, 2012
No sound. It flashes protect.
Your device has went into protection mode, an internal malfunction causes it to shut down in order to protect itself.Somtimes a physical reset will help.Turn of and unplug device fro a couple of hours Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2/16/2012 12:58:02 AM • Sony STR-DE345... • Answered on Feb 16, 2012
Loud buzzing sound in the
The buzzing is caused by the power source of the receiver : the filtering capacitors from the power lines to the amplifier circuits have aged and have started to dry, lose their capacity so the current is no longer filtered correctly so the ripple from the AC mains is stronger and it's passed on to the amplifiers where it became audible.
Keeping the capacitors under constant tension will help them regenerate somewhat, but you will have in the end to replace them. A simple job, just be careful at the ratings of the capacitors when you get their replacements.
7/26/2011 5:33:17 PM • Sony STR-DE345... • Answered on Jul 26, 2011
When i push a button
Hello, that happens when a reciever gets a few years old and only the remote control has been used.The switches are dusty i recommend pushing them in 50 times each ,i know it sounds silly but it will clean the contacts.
2/22/2011 9:27:54 PM • Sony STR-DE345... • Answered on Feb 22, 2011
I keep getting a protect
If it's not heat you may not be able to resolve it yourself. A technician might.
2/21/2011 7:42:52 PM • Sony STR-DE345... • Answered on Feb 21, 2011
2answers
My STR-DE345 has no sound from the center channel,
The center channel on this model uses its own amplifier circuit that is independent from the others. It is usually a 5-9 pin IC attached to the heatsink. It is likely that this IC is defective and needs to be replaced. Unfortunately, I can not know this for sure without taking measurements inside the unit. There is no simple fix for this although this is an easy repair for a service shop. Please seek professional assistance to resolve this. Expect a parts cost in the $25 range.
Dan
1/28/2011 12:22:03 AM • Sony STR-DE345... • Answered on Jan 28, 2011
My fuse keeps blowing, what
May be a number of things...the power supply may have a shorted component in it...or the audio output stage may be defective...if you can obtain a volt/ohm meter you can test the power supply diodes and the regulator/audio output transistors...you will need to use the diode check function or the ohm scale to check these semiconductors...they should read infinity in one direction and , on diode test, anywhere from 500-700 for silicon(which is what is used today)..on the ohms scale you should read 500-2000 ohms in one direction and infinity in the other...if you get a 0 reading on any of the semiconductors..then it is shorted and will need to be replaced
1/7/2011 4:08:23 AM • Sony STR-DE345... • Answered on Jan 07, 2011
Sony STR-DE345 Receiver Logo
63 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
loud buzzing sound in
  • Audio Players & Recorders
