20 Most Recent Sony STR-DA5ES 6.1 Channels Receiver Questions & Answers
Marko,
I own the same unit (since 2001) & have had no problems. I would get it looked at & see what the issue is & what it would cost to fix. Would it be worthwhile? Well you'd have to ask yourself how much $$ you'd be willing to spend on a replacement vs repairing this unit & based on how much you'd be willing to spend, would the specs on a replacement unit measure up. You'd have to ignore things like HDMI inputs to keep it apples to apples.
I've owned various Sony components for a long time. I only had to get one unit fixed one time (a CD player that my one year old decided to do a chin-up on :( ). The unit was 7 years old at the time and my son is now 12!!. the unit still functions flawlessly since being repaired. Sony builds their stuff to last, even after beiung abused.
Sony STR-DA5ES... | Answered on Aug 06, 2010
Had same issue, found out it only uses RCA jacks, no optical input will feed to 3rd room. Bummer
Hi have Sony STR-AV 970 not getting any sound from receiver panel lights up, and the FM
Station is up and running but no sound from either A/B speakers as well as the phones
Sony Audio... | Answered on Jan 21, 2020
if all connected correctly check see if fuses inside or outputs could be blown
Sony Audio... | Answered on Dec 18, 2019
Find out why your Sony is in protect mode and repair it to restore normal operation. This is a common problem with Sony equipment and often is traceable to cold or poorly soldered connections.
Sony Audio... | Answered on Dec 17, 2019
Probably the changer mechanism has failed. You will have to disassemble your Sony unit to salvage the discs. As a test, try playing a single disc. You may be able to use your Sony in a limited way.
Sony Audio... | Answered on Dec 15, 2019
Take it apart an on the rear of the display you will see capacitors. You will probably see an end cap that is domed. Just replace them all.
Sony Audio... | Answered on Dec 10, 2019
Try this and let me know. First unplug the unit. Plug it back in. When you first push the power button, you should hear 1 click followed by another withing 5-20 seconds. My guess is that you don't hear the second click. Am I right?
Sony Audio... | Answered on Nov 30, 2019
You have this backwards. Applicable code(s) will be found in the remote control, if it is compatible.
Sony Audio... | Answered on Nov 28, 2019
Applicable code(s) will be found in a compatible remote control.
Sony STR-DA5ES 6.1 Channels Receiver Logo
Popular Tags
5 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
third room no sound comming from when
  • Audio Players & Recorders
