20 Most Recent
Standard Horizon CP150 GPS Receiver Questions & Answers
Standard Horizon CP150 internal battery
You must open the unit up to get to the battery .The battery should be a 3 volt lithium cell that is soldered directly to the main circuit board .If you are not experienced in electrical - DO NOT ATTEMPT .Take it to someone experienced .If you need assistance call 1-800-701-4008
Power cord
I called standard horizon myself and bought the power cord for $25. The # 714-827-7600
Standard Horizon CP-150 won't find satellites
Robert
It could be the RAM inside the plotter needs to be reset, Try the following procedure:
RAM Clear
Please note this procedure will erase any saved user points such as marks and routes and will put all of the internal settings back to factory default. In addition the unit will have to reacquire satellite signals, which may take a minute or two. If you have a large number of routes and/or marks you may wish to save them to a User C-Card prior to performing the RAM clear. The User C-Card is a blank memory card that is available through your local dealer or can be purchased from C-Map directly by contacting them at (800) 424-2627.
1) With power to the GPS turned off press and
hold the ENTER key.
2) Now press and hold the PWR key.
3) Keep both keys pressed until the GPS screen lights up and you see the SYSTEM TEST page displayed, then you can release both keys.
Note: If the GPS is not able to be turned off using the PWR key you can turn power off at the breaker or disconnect the power cable, press and hold the ENTER key then turn the breaker on or plug the power cable back in.
4) Make sure that the RAM menu function is selected, then press the ENTER key.
5) A sub-menu will appear that has two selections; RAM test and RAM clear, move the shuttle point knob down to select RAM clear.
6) Press the ENTER key, a prompt will appear asking if you are sure that you want to clear the RAM. Press the ENTER key to confirm and a prompt will now appear that informs you that the RAM has been cleared.
7) Press the CLEAR key and you will be back on
the SYSTEM TEST page.
8) Press and hold the PWR key until the unit turns off, then press and hold the PWR key until the unit turns back on again.
What do you think about new york city exterminators?
There are various websites on internet that are presenting new york city exterminators. These are specially-made for those people that are trying to find quality service. To find out more please visit with this site :http://www.mypestsolutions.com/
4/18/2024 4:19:04 AM •
GPS
Answered
on Apr 18, 2024
