20 Most Recent
Classic Electronics AP191 CD Boombox Questions & Answers
While CD, we read err
chances are the lens on the optical pickup is dirty and needs cleaning. you can blow out any dust with canned air and use a lens cleaning disk to clean off the lens. they sell them at any electronics store. if that doesn't work or the disk doesn't spin at all, you'll have to replace the optical pickup assembly or the whole cd player..
12/17/2009 2:27:17 PM •
Classic...
Answered
on Dec 17, 2009
Owners Manual Replacement
Check out this web site http://www.audiocircuit.com/index.php?c=LUX&cc=940&m=D-351# Looks like they will be able to help you.
2/17/2009 12:24:49 AM •
Classic...
Answered
on Feb 17, 2009
Play CD deck through pc
Hi and welcome to FixYa,
Yes, it is possible. The Cambridge CD4 deck would be an external signal source of the sound card of the computer. Basically, the R/L Audio OUTPUT of the deck would be connected to the AUX or LINE IN of the PC. A RCA to stereo 3.5mm plug would be needed similar to what is shown below.
Thereafter, enable the AUX/LINE IN in both playback and recording modes of the Volume Control Properties.
Good luck and thank you for using FixYa.
2/13/2009 11:46:52 AM •
Classic...
Answered
on Feb 13, 2009
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
