20 Most Recent Sylvania SRT2319 TV Questions & Answers
A remote control is a must to proceed.
Sylvania SRT2319... | Answered on Oct 23, 2013
2327 2304 2314. These are the codes to check. If you wish to get more, http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sylvania SRT2319... | Answered on Aug 27, 2013
0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Sylvania SRT2319... | Answered on May 05, 2012
you will have to call the number on the back of the TV. There you can by a remote. I had the same problem.
Sylvania SRT2319... | Answered on May 04, 2012
Your TV has bad solder connections at the set's verical output integrated circuit. It's very common for these connections to go bad because of heat from the part. When the technician moved the set around to hook up your new box, it may have jarred the connections enough to finally cause the existing problem to become more obvious, but he didn't cause the problem. Your set would probably be doing this anyway before long. The good news is that it's just a simple fix. Resoldering the connections should restore normal operation.
Sylvania SRT2319... | Answered on Jul 15, 2011
What device do I need to receive network TV without cable connection?
Sylvania SRT2319... | Answered on Jul 05, 2011
Hello
Three digit universal remote codes for Sylvania TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 133/ 161/ 163
Four digit universal remote codes for Sylvania TV are:
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sylvania SRT2319... | Answered on Jun 11, 2011
If you are able to access the internet, I would suggest try getting your question answered by searching online. Several sources have answers to your question. They may not be the solution, but worth a try. Who knows, one of them just might work. Most of the time, it just takes a little patience and plenty of persistence. Be willing to spend some time searching. You might start by typing into the search box exactly what you're looking for. Good Luck!
Sylvania SRT2319... | Answered on Mar 18, 2011
get a RF modulator if the tv does not have rca connectors. get it at radio shack or wal-mart
Sylvania SRT2319... | Answered on Aug 31, 2010
Buy the remote from :-
http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=N0139UD
Good Luck!!
Thanks!!
Sylvania SRT2319... | Answered on Aug 17, 2010
hi! i have here a couple of codes for your sylvania tv, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483, hope this helps!!! goodluck!!!
Sylvania SRT2319... | Answered on Jun 09, 2010
if you have the silver comcast remote with the red button in the middle, then try pressing tv then hold setup until it blinks, then hit 993. it will blink again, then hit channel up until your tv shuts of. when it does hit setup to save
Sylvania SRT2319... | Answered on May 07, 2010
Sylvania SRT2319 TV Logo
51 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvania srt2319
  • Televison & Video
