20 Most Recent Sylvania 6420FB 20" TV Questions & Answers
This problem may be more complex than just the selection of a channel to receive video. The first problem is what channel to receive the video. Usually its received on channel 3 or 4. You select that on the video output and match it on the TV. That assumes your recorder is attached via the RF (antenna) connection. If its hooked up via the component connect then you must have a remote to select IN1 or IN2 on the TV to receive video. Remote controls are available on line. Do a search on your TV model and remote control.
Sylvania 6420FB... | Answered on Jun 10, 2016
try changing the channels until you reach 2 and go past it.
Sylvania 6420FB... | Answered on Aug 23, 2014
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Try your format button... or your wide/size button... they're all a bit different but they all have different screen size capabilities.
hope this helps
Sylvania 6420FB... | Answered on Aug 01, 2013
Check its secondary power supply voltage from SMPS power supply. Check the smoothing capacitor connected to secondary power supply voltage, replace it.
Sylvania 6420FB... | Answered on Jun 14, 2012
Try website like Remotes.com to buy the tv original remote.
Sylvania 6420FB... | Answered on Jun 11, 2011
Hi, well ALL TV's can be controlled from the Buttons ON the actual TV itself, look carefully on the TV, you will find a set of buttons, usually about 7. They should be marked, ON/OFF, CH UP, DOWN, MENU, ENTER/OK/SELECT, VOL UP/DOWN. Now Multiple presses will access differing features on the set, usually after pressing the ON/OFF button, you press the menu button and select your Input, Tuner, external, etc, once set, you Change the channel with the UP/DOWN key, and the Volume with the -,+ Key.
It's all in the user manual in the download link below.
http://www.devicemanuals.com/guide/Television/Sylvania/Sylvania-6420FB-20-TV-User-Guide-TmpJek9UZz.html
Sylvania 6420FB... | Answered on Sep 09, 2010
U can't get to channels 3 or 4 without a remote.Ur getting stuck on these particular channels 26,35 and 19 mean the last owner put these channels on the tv memory.Try website like Remotes.com to buy an exact remote or very close to the original,if u want make use of this tv.
Sylvania 6420FB... | Answered on Jun 15, 2010
Remote codes are part of the universal remote, not the TV. Try the Sylvania codes in the manual with the remote. If the code is not there, the REMOTE does not have the instructions to run the TV.
Sylvania 6420FB... | Answered on Mar 21, 2010
Sylvania 6420FB 20" TV Logo
28 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
not able put
  • Televison & Video
