20 Most Recent Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Questions & Answers
Sylvania TVs are made by Funai Corp. You should try any Funai codes that are listed for the Synergy V remote. Alternatively, you can try the code search method, point and search. See http://help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC-U62CDR/index.htm#Point_and_Press_Programming for the details. One Synergy V remote code list is available in this copy of the manual: http://help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC-U63CDR/RC-U63CDR.pdf . I found the codes for Funai to be 047 048 157 168 211 .
I hope this helps.
(For my TV, the search all codes is often better for universal remotes. The brand name codes listed didn't work; searching all codes found an exact match for all the features that I use.)
Sylvania SRPD442... | Answered on Feb 05, 2018
DOES THE TV STAY ON ??DOES IT TURN OFF?...MOST CASES IS A FAILURE IN ONE OF THE POWER PROCESSING BOARDS..WHICH MEANS THAT HAS TO BE REPLACED..
Sylvania SRPD442... | Answered on Mar 18, 2011
It should be on the back of the tv near the middle. See the instructions at the following link:
http://www.sylvaniaconsumerelectronics.com/support/connection.php
Good luck.
Sylvania SRPD442... | Answered on Feb 01, 2011
A bad capacitor is a possibility, but lets define the problem first.
The set is shutting down because a problem is detected. This is commonly known as "protect" mode. With plasma sets, there are many reasons for this to happen. There are effectively at least 2 stages of power supply inside these sets. 1) The standard power supply that drives the video processing etc and 2) the plasma suplpy. A fault in either supply stage can cause this problem. I would not suggest just changing capacitors without an understanding of the function of that part. The cap may have been damaged as the result of another part failure. Just changing the cap without furthrer investigation can lead to more problems. This may not always be the case, but it can happen. At the very least, I would suggest that you invest in a detailed repair estimate from an authorized service center. At least that way you can have some cinfidense that the repair will be correct and long lasting.
Dan
Sylvania SRPD442... | Answered on Aug 26, 2010
You did not specify Mac model nor connection cable. Let me make a stab at it. ED means this is a 480-line interlaced or progressive, not sure. So you will need to select 640x480 plain or stretched. This based on what my MacBook Early 2009 white allows. I assume you are using an HDMI or DVI connection from a mini-DVI (mine) or the newer mini-DisplayPort. (I bought an ~$10 adaptor from monoprice.) -Ken
Sylvania SRPD442... | Answered on Apr 11, 2010
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Sylvania SRPD442... | Answered on Jan 16, 2010
There is no cable connection. This set is a monitor and you need cable or satellite.
Sylvania SRPD442... | Answered on Dec 06, 2009
There is none, you need to use a cable or satellite box with this TV. It's a monitor with no tuner.
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sylvania SRPD442... | Answered on Sep 24, 2009
go to the sylvania website,and go to support,there should be a section for manuals there and you can either download it or just read it online,hope this helps.
Sylvania SRPD442... | Answered on Jan 14, 2009
The fault can be the screen itself, or one of the driver boards for the screen. This has to be verified by trying the boards.
I don't know for your model if the backplane lamps can be replaced. In most of the models they can be.
Jerry G.
Sylvania SRPD442... | Answered on Jan 04, 2009
tot2523, your on off switch needs to be replaced. We have one, and we are now on our 2nd repair of the switch. First one blew and now the power switch won't go on. It seems it is a flaw with this t.v. Our t.v. is only 2 years old.....
Sylvania SRPD442... | Answered on Oct 07, 2008
If the line is vertical in nature then most likely then the plasma display panel is bad and won't be worth fixing because of cost. If the line is horizontal then the issue might be a lower or upper Y-buffer module.
Sylvania SRPD442... | Answered on Jun 09, 2008
This could be anything but is more than likely a problem in the power supply or control board. There really are not any user serviceable parts in these units and they have dangerous voltages. Repair is best left to a professional.
Sylvania SRPD442... | Answered on Jun 08, 2008
This can be many types of faults. The set will need shop service. There may be cold solder connections on one or some of the boards, or there may be come components that are intermittant. In anycase most of the time, there will be the need for board replacments.
The cost for this type of repair can be fairly expensive. I would consider investing in to a new set because after having this serviced, there will still be many older components in the set that can potentialy fail.
Jerry G.
Sylvania SRPD442... | Answered on Apr 18, 2008
Call the tech support for your TV set. There may be a servcie setup fault, or a component failed that controls the placement of the text, or it may even be a user setup that can be done.
If there is a failure, the set will have to be serviced.
I would guess that you refered to the user manual for any possiblity that there is a setup for the placement of the text...
Jerry G.
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
40 questions posted
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvania monitor say format not suppoted
  • Televison & Video
