20 Most Recent Wharfedale Moviestar 70+ System Questions & Answers
It sounds like you have it all figured out. Is it a problem? After all, it's just labeling.
Wharfedale... | Answered on Jun 21, 2011
do you have a cable box? with your wharfdale set-up, you could run the video from the cable box into the tv, and run the seperate audio oupputs from the cable box into the wharfdale.
thats really the most common way to run audio, either that or through hdmi- either way, you will need to hqave a cable box to complete the set-up, cause not that many tv's have audio or hdmi outputs.
Wharfedale... | Answered on Oct 12, 2010
you can find it here:Twilight Saga: Eclipse
have a good time
Wharfedale... | Answered on Jun 10, 2010
is this installed in a vechile or free standing
Wharfedale... | Answered on Aug 14, 2009
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Wharfedale... | Answered on Mar 11, 2009
Ciao Antonio, per prima cosa scollega il segnale audio che entra nel subwoofer, verifica che abbia il volume a zero, se il rumore continua, ha problemi di rumore dall'alimentatore,
Se il rumore scompare, sostituire il cavo audio che fornisce il segnale al subwoofer
Hola Antonio, primero desconecte la se?al de audio que ingresa al Subwoofer, verifique que tenga el volumen en cero, si el ruido continua, tiene problemas de ruido por la fuente de alimentaci?n,
Si el ruido desaparece, reemplace el cable de audio que le entrega se?al al subwoofer
Wharfedale Audio... | Answered on Apr 15, 2019
Wharfedale Moviestar 70+ System Logo
14 questions posted
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Wharfedale Audio Players & Recorders
Most Popular Question
42 lg plasma tv number
  • Audio Players & Recorders
