20 Most Recent Sylvania 6240VE VHS/S-VHS playback VCR Questions & Answers
I have a sylvana Model
Yes, change the date. To the 4th which is Monday and save it.
But, you will have to make sure the VCR is turned on 24hrs a day, 7days a week. You can just turn it off from the power button and it will be on standby. What I am trying to say is that you should avoid removing the plug from the wall so that the recording time will not reset or be in disorder.
I hope the above makes sense to you.
Good luck.
4/7/2011 3:29:35 PM • Sylvania 6240VE... • Answered on Apr 07, 2011
Lost manual and i can't get vcr to record
You can find your manual here:
http://www.funai-corp.com/6pdf/om/C6240VE.pdf
Download (Adobe acrobat) PDF format and read.
Hope this helps.
8/25/2010 6:35:38 PM • Sylvania 6240VE... • Answered on Aug 25, 2010
2answers
Vcr says that there is a tape inside of the vcr when there isn't
Most VCR's do have a sensor system inside. It consists of what looks like a bar that is standing up right in the middle of the area the tape sits down into, and sensors on one or both sides of the tape bay that detect this source. The source is usually an infrared diode, and it is most likely this diode that has malfunctioned. I would checjk to see if anything has gotten inside that might be blocking this sensor, if not then the diode probably needs replaced.
7/15/2010 5:11:14 PM • Sylvania 6240VE... • Answered on Jul 15, 2010
Owner Manuel for Sylvania 6240VE 4-heads VCR
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa
5/10/2010 6:26:49 AM • Sylvania 6240VE... • Answered on May 10, 2010
I have a Sylvania 6240VE vcr. When I try to rewind
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
7/23/2009 4:13:10 PM • Sylvania 6240VE... • Answered on Jul 23, 2009
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
2/15/2009 2:55:09 PM • Sylvania 6240VE... • Answered on Feb 15, 2009
Jumping screen on sylvania 6240ve
Press the Channel up & down buttons at the same time and on most VCRs this deactivates auto tracking option. then press the up or down channel button to adjust tracking.You might try this first. pressing them both at same time reactvates auto tracking. This might not solve the problem but at least you eliminated one possibility.
8/25/2008 6:11:54 PM • Sylvania 6240VE... • Answered on Aug 25, 2008
Recording
here is a link to download the manual for your vcr - http://www.usersmanualguide.com/funai/video_cassette_recorder/6240ve - hope this solves your problem.
9/20/2007 3:51:40 PM • Sylvania 6240VE... • Answered on Sep 20, 2007
2answers
Can I use a universal remote app for sylvania LC320SL1
Hi. It depends on the remote. If the remote app has the codes for your Sylvania tv, then you can use the remote. Check the list of codes that comes with the remote app and if it includes Sylvania codes, then there is a high possibility that the app will work with the tv. Thank you.
11/26/2022 4:16:02 AM • Sylvania... • Answered 3 days ago
Is there a remote app I can use for sylvania LC320SL1 tv
The Sylvania LC302SL1 is not a smart TV. You can only use an IR remote to control the TV. (A replacement remote is available here: https://www.walmart.com/ip/Replacement-LC320SL1-HDTV-Remote-Control-for-TV-Sylvania-Compatible-with-NH000UD-Sylvania-TV-Remote-Control/511772228 .) Otherwise, look for any universal remote that was programmed in 2011 or later. (Usually it takes 6 months or so for the universal remote manufacturers to get codes for new TVs. The Sylvania LC302SL1 manual has a copyright date of 2010.) There was a period when some phones and tablets included an IR transmitter. If you have one of these, then look for an IR blaster (TV remote) app on the appropriate store. I hope this helps. Cindy Wells
11/26/2022 1:05:04 AM • Sylvania... • Answered 3 days ago
2answers
Replacement tv base/stand
Hi, Please check ebay and amazon for the replacement base/stand. If not available, you can reach out to your local Target or Bestbuy to see if they have anything in their catalogs. Thank you.
11/5/2022 1:33:58 AM • Sylvania... • Answered on Nov 05, 2022
2answers
How do I connect my Sylvania TV to an antenna?
Just connect it to its antenna input socket. That's all.
9/26/2022 5:05:18 PM • Sylvania... • Answered on Sep 26, 2022
2answers
I have a portable DVD player Sylvania SDVD7046 and when I put a movie in, I can hear it but the screen is black, why is it doing this please?
It is doing it because it is broken. You need a new one or take it into an electronics engineer.
7/14/2022 7:07:14 AM • Sylvania... • Answered on Jul 14, 2022
2answers
My Sylvania TV MODEL NO.LC320SLX has a light flashing after ripping over. Nothing is working. What does the flashing light mean?
Unfortunately, this set may not be worth repairing, it has a main and power board combo and your issue is in this board according to Funai, the parent company of Sylvania's service info. If you can find a board reasonably it should fix the set but considering its about 10 years old it may make more sense to replace the TV. It's also possible the screen was damaged when it fell, in some cases you can't see the damage.
6/25/2022 7:00:09 PM • Sylvania... • Answered on Jun 25, 2022
Sylvania 6240VE VHS/S-VHS playback VCR Logo
16 questions posted
Top Sylvania Televison & Video Experts
Marvin
Marvin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvana model
  • Televison & Video
