20 Most Recent Sylvania SRCD227 27 in. TV/DVD Combo Questions & Answers
SRCD227 tv/vcr/dvd won't stay on
QUE CLAVE O TECLAS DEBO OPRIMIR PARA ENTRAR AL SETUD
11/29/2011 4:38:16 AM • Sylvania SRCD227... • Answered on Nov 29, 2011
Sylvania tv gets thin line where picture should
The problem is in the circuit board, there are bad solder connections near the high voltage transformer and the vertical deflector ic. If you are handy with a soldering iron unplug set, remove the back cover, "several screws" and check the underside of the board on the right side, when in dought touch up with soldering iron.
6/20/2011 12:49:47 AM • Sylvania SRCD227... • Answered on Jun 20, 2011
2answers
The tv will turn on but the power goes off after
in the supply board change the condensers for news ones
3/2/2011 6:10:29 PM • Sylvania SRCD227... • Answered on Mar 02, 2011
0answers
Dont have the remote and need to set channel to
Try programming the remote to your tv this link will show you codes and instructions.
Hope this helps!!!
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
1/19/2011 12:48:51 AM • Sylvania SRCD227... • Answered on Jan 19, 2011
Why does my t.v. automatically shut off after 15
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
1/17/2011 6:38:01 PM • Sylvania SRCD227... • Answered on Jan 17, 2011
How to connect a additional speaker
Hi my name is John. Welcome to FixYa. Look in the back of TV you will see plug jack, just plug speaker in. Thanks for choosing FixYa....John
12/1/2010 6:07:48 AM • Sylvania SRCD227... • Answered on Dec 01, 2010
When tv is pluged in and turned on it shuts of
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High Voltage were detected.
6/1/2010 2:35:17 PM • Sylvania SRCD227... • Answered on Jun 01, 2010
I need the codes to program tv on the urc-3220
I can help you with your URC-3220 Universal Remote Control issues.
The codes for Sylvania TV's are: 0054, 0030, & 0171.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
5/30/2010 6:32:22 AM • Sylvania SRCD227... • Answered on May 30, 2010
Red/ Bright Tint/Color on Sylvania SRCD227
Your Logitech Harmony 550 is able to learn commands that are not included in its command database.
To teach your Harmony 550 a new button follow these steps:
  1. Connect your Harmony remote to your computer to start the Harmony remote control software.
  2. Click Devices.
  3. Click a device.
  4. Select Learn Infrared Commands.
  5. Click Next.
I hope that helps.
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
4/30/2010 3:03:13 PM • Sylvania SRCD227... • Answered on Apr 30, 2010
Doesn't work with universal remote
I have the same problem i have a magnavox tv/dvd/vcr and none of the codes work can you help me out
7/25/2009 2:04:03 AM • Sylvania SRCD227... • Answered on Jul 25, 2009
Tv won't stay on
check the power cord and make sure it hasn't accidentally been cut or if its detatchable make sure its all the way in
7/31/2008 2:18:06 PM • Sylvania SRCD227... • Answered on Jul 31, 2008
Help
Move anything magnetic or any sound producing electronics away from you television. This includes stereo speakers or alarm clocks. Give your TV 30min. to 1hr. to cooldown completely and see if that fixes your problem.
7/31/2008 2:15:28 PM • Sylvania SRCD227... • Answered on Jul 31, 2008
2answers
TV does not start
There is problem in your Display. It does not run when it becomes hot.
12/27/2007 12:11:13 AM • Sylvania SRCD227... • Answered on Dec 27, 2007
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
12/10/2007 12:04:10 AM • Sylvania SRCD227... • Answered on Dec 10, 2007
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same. www.dvdenergy.com/index.htm
8/10/2007 5:31:13 AM • Sylvania SRCD227... • Answered on Aug 10, 2007
Sound but no picture
Is hard to tell what might be happening but the set has wires coming from the chassis to the crt board,backtrack your steps and check the conectors,ussually they can only fit one way and can not be forced in,make sure they have not been switched and stay away from the thick red lead coming from the output transformer to the back of the picture tube,it has high voltage and it can hurt a grown up man easily,the crt board in the neck of the picture tube nneds to be pushed in all the way,just checked that is in and if you have to remove it make sure you pull straight out and do not twist it because one of the pins in the crt might break,if you took it out before just check that one of the pins is not bent.Let Us know if you need more information.
10/31/2006 11:53:03 PM • Sylvania SRCD227... • Answered on Oct 31, 2006
Sylvania SRCD227 27 in. TV/DVD Combo Logo
27 questions posted
Top Sylvania Televison & Video Experts
Marvin
Marvin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
help
  • Televison & Video
