20 Most Recent Uniden BC796D Base Scanner Questions & Answers
check uniden web site should find info. JR
Uniden BC796D... | Answered on Sep 10, 2016
  • Hi, I can help.
  • This happens a lot to people just setting up a scanner like this. Try these suggestions, I think you'll be up and running in no time.
  • You have to make sure the BAUD rate is set and make sure your PC control is turned on in your scanner. A BAUD is the rate per second data is sent.. A BAUD rate of 38400 (or what ever BAUD the software is at). I think parts 3,4 and 5 in the your scanner menu cover this. If you have the FIFO buffer set then remove it from your settings > control panel > comm ports. You will get the best results if you have that software read the bank before writing to it. Relabel your comm port settings if you need to as well ie. port 1, port 2 etc.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Uniden BC796D... | Answered on Sep 21, 2011
because all of your banks are locked out....
Uniden BC796D... | Answered on Jul 17, 2011
Just program a p-25 apco into a regular channel of your scanner... in your conventional scan mode...Just go to a certin channel of your scanner and program it in and it will automatically come in the APCO -P25...I have one of these scanners....ITs a wicked scanner...a good one...
Uniden BC796D... | Answered on Jul 16, 2011
it could be that your telescopic antenna that you got with your scanner could be Bad try putting another antenna on it. or try an outside base scanner antenna....
Uniden BC796D... | Answered on Jul 14, 2011
For a comprehensive database of active frequencies in your area (they're not codes), and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Uniden BC796D... | Answered on Feb 23, 2011
www.uniden.com/pdf/BC796Dom.pdf -
Above is your manual and below is your support site, use these to do as you want, it is all explained in the manual, if you get stuck, contact them direct.
http://www.uniden.com/products/productdetail.cfm?product=BC796D
Uniden BC796D... | Answered on Jul 10, 2010
Setting DELAY for All Search Ranges
You can set the scanner to have a delay after the end of a transmission before searching
resumes. This slows searching, but helps you prevent missing replies on a frequency.
1:SERVICE OPTION → :CHAIN SEARCH → 3:DELAY
1:NONE
The delay is turned off.
2:1 SECOND
The delay time is 1 second.
3:2 SECONDS
The delay time is 2 seconds.
4:4 SECONDS
The delay time is 4 seconds.
28
5:INFINITE
When the scanner stops on a transmission, you must press RSM to resume
searching.
6: -2 SECONDS
The scanner only stops on transmissions for 2 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 2-second pause.
7: -5 SECONDS
The scanner only stops on transmissions for 5 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 5-second pause.
8: -10 SECONDS
The scanner only stops on transmissions for 10 seconds, then automatically
resumes. To hold on the transmission, press /HOLD during the 10-second pause.
Uniden BC796D... | Answered on May 23, 2010
For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Uniden BC796D... | Answered on Apr 27, 2010
Try tuning known frequencies, such as the NOAA weather channels, to verify the working condition of your scanner. If it picks them up, you don't have your local police system/frequencies programmed properly. If there's no reception, even on NOAA, you have an antenna or receiver problem that may need professional attention.
In case you need it, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
You can download a manual for this unit at, BC796DOM.pdf it is 84 pages....hope this was helpful...
Uniden BC796D... | Answered on Apr 26, 2010
Thats as long as it will delay... hope this helps..
Uniden BC796D... | Answered on Mar 25, 2010
Uniden BC796D Base Scanner Logo
21 questions posted
Top Uniden Radio Communications Experts
Jason
Robert McClure
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Radio Communications
Most Popular Question
comunication error 796d
  • Radio Communications
