20 Most Recent Fuji FinePix A120 Digital Camera Questions & Answers
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa. Organize edit and share your photos
Fuji FinePix... • Answered on Nov 15, 2014
Hi there i am sure its a problem with the camera CCD. but you can try a basic steps for resolve the problem.I inform you that if the solution not work then you need to replace the CCD.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Fuji FinePix... • Answered on Feb 13, 2011
If your camera is truly the Finepix A120, it uses xd picture cards, not SDHC cards.
Fuji FinePix... • Answered on Dec 20, 2010
Hi, the first thing to try would be to get another memory card for the camera as it could just be that the card is no longer working, failing that the problem will be with the firmware on the camera and this will need taking it to get sorted, try the memory card first and see what happens.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Fuji FinePix... • Answered on Sep 17, 2010
Either the camera is having a battery problem, or a lens issue:
Here are a couple sites that explain what you can do to try to correct this:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though the article is entitled "lens error", it also applies to stuck lens issues.
Good luck, hope this helps, and thanks for using FixYa.
Fuji FinePix... • Answered on Sep 16, 2010
you must go to menu and select format card, this should resolve the issue.
Fuji FinePix... • Answered on Aug 10, 2010
If your camera has a serial number starting with 4Bxx og 4Cxx, you may need to update the firmware.
Firmware is available her: http://www.fujifilm.com/support/digital_cameras/software/#firmware
Fuji FinePix... • Answered on Aug 06, 2010
What happens when you try to format the card in the camera?
Fuji FinePix... • Answered on May 17, 2010
If your camera has a serialnumber starting with 4B or 4C, you need to update the firmware to the latest version. Firmware can be downloaded here:
http://www.fujifilm.com/products/digital/download/a120/fupd.html
Or, if your card just needs to be formatted:
Press Menu/OK, select Set, select Setup, select Format, press OK.
Fuji FinePix... • Answered on Mar 25, 2010
you could try doing it manually, go to my computer open your camera, and select your pic files and ctr+c and ctr+v on folder where you want them to be or just drag them to my pictures folder or wherever you want
Fuji FinePix... • Answered on Aug 01, 2009
Try this site for a firmware update. You need to get a AC power adapter for it to work though. It is from Fuji and it worked fine for my A120. The older XD cards are of a different format then the newer ones so if your new XD card has an 'M' on it you will need to do the firmware solution.
Good luck
http://www.fujifilm.ca/x3719.xml
Fuji FinePix... • Answered on Jul 13, 2009
change the image size
Fuji FinePix... • Answered on Jul 10, 2009
Please read all of post first!
try reformating thd sd card BUT remember everything on the card will be lost. I'v had that happen when I moved my card to another piece of equipment and then back again.
IF there ARE pictures on the card then try another card reader to pull them off before formating the card.
some copyers, scanners, even some pc's have readers in them, or maybe a freind.
hope that helps :)
Fuji FinePix... • Answered on Jan 27, 2009
try resetting the camera!
Fuji FinePix... • Answered on Jan 01, 2009
Has it always done this or only since you started standing on your head?
Fuji FinePix... • Answered on Sep 10, 2008
You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
It is a Fuji site and it works.
Good luck.
Fuji FinePix... • Answered on Jul 27, 2008
if you have XP or Vista, just go to "My Computer" and you will see your card as another removable memory/media, double click on it and you'll see the folders for your card.
good luck
Fuji FinePix... • Answered on Jun 24, 2008
Try looking at http://www.fujifilm.ca/x3719.xml for firmware or software updates as well as new drivers for your camera. If you are using an upgraded XD card try putting the original back in.
Then follow the directions for doing the updates to use your new card. If all else fails time for a new camera.
Good luck and have a great summer.
Fuji FinePix... • Answered on Jun 20, 2008
Fuji FinePix A120 Digital Camera Logo
33 questions posted
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
need fix camera ahve digital
  • Cameras
